11-21-2015, 17:08 | #1 (permalink) |
Freak Poster Join Date: Jul 2006 Location: pakistan
Member: 319303 Status: Offline Thanks Meter: 22 | Check battery , cable , drivers and try try again now i am trying to flash but coming this error Code: Card found : S/N : CF3E846E , v0129 Chinese Miracle II [MTK module] v 1.37 Scatter Load Ok , BaseBand : MT6589 , Project : MTK6589 , Storage : eMMC Files found : 12 , Set to Flash : 11 Ready to Flash! Operation : Flash [ v1.37 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 4B000115303055335AA8124D99707568 DA Stat : v3.2 on BBID : 0x86 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00B8 DRAM Init Ok , 0x40000000 DA Sent. Configure setting now ... DA start Failed at final stage! Check battery , cable , drivers and try try again Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! Operation : Flash [ v1.37 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 4B000115303055335AA8124D99707568 DA Stat : v3.2 on BBID : 0x86 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00B8 DRAM Init Ok , 0x40000000 DA Sent. Configure setting now ... DA start Failed at final stage! Check battery , cable , drivers and try try again Boot Error! Operation Failed Elapsed: 00:00:19 Reconnect Power/Cable! Operation : Flash [ v1.37 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 4B000115303055335AA8124D99707568 DA Stat : v3.2 on BBID : 0x86 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00B8 DRAM Init Ok , 0x40000000 DA Sent. Configure setting now ... DA start Failed at final stage! Check battery , cable , drivers and try try again Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! |
