03-14-2008, 17:23 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Dear Friend, There are different "Chinese" phones with the same name but absolutely different hardware exist on market. Example: exist at least 30 "Chinese" phones with name "N95", at least 20 models "N73" etc. but all models has difference in hardware, different bottom connectors, different pinouts and and has different firmware, so it's impossible to give any advice about phone pinout only by phone name. So we recommend you to include the next information in your request regarding pinout: 1. detailed description of model: brand name, model name, complete text from phone back label, any other marks that you can find on phone cover 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, you can find pinout by yourself more easy than before, just check the next detailed description how to get pinout for your model: 1. use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 2. if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ 3. if not helps, please read: http:///vbb/showpo...36&postcount=7 4. if not helps, please read: http:///vbb/showthread.php?t=433447 Universal solution for pinout detection: http://www.infinity-box.biz/index.ph...infinder&lg=en Regarding 2nd sim: probably need to repair 2nd CPU software (flash it or make format). |
03-14-2008, 22:47 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! measure voltage on all pins and detect needed by voltage near 2,7-2,8 volts. step by step tutorial in our FAQ section "second and tested way to find pinout" |
I can't use my Chenese Cocktail, why? | BackSlash_cu | PadFinder box | 3 | 02-23-2010 06:48 |
chenese nokia connecting error | achi_nokia | Infinity-Box | 1 | 02-09-2010 20:48 |
Chenese miracle no select flash why? | sancakaziz | Infinity-Box | 3 | 11-09-2008 11:00 |
chenese Nokla n72 | asco777 | Infinity-Box | 9 | 10-05-2008 20:03 |
chenese miracle mistake | asco777 | Infinity-Box | 8 | 05-29-2008 16:56 |
