Old 11-13-2015, 09:35   #1 (permalink)
Member: 1166901
Sonork: Ginerz
Thanks Meter: 28
cherry flare s3 smart AV done..
hung on start up after few sweconds ts problem
no scape from smart av
first read bkup
Operation : Read Flash [ v1.36 ]
Wait for phone...
Phone found! [ 17 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CB00
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BB_CPU_NM : [MediaTek] MT6582_S00
Processing BROM stage
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v7.1533.03
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 1501004B3758564D4201624F5512B197
DA Stat : v4.2 on BBID : 0x87
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0015 , OEM : 0100
[eMMC] : FLASH_INF : BMVX7
[eMMC] : FLASH_CID : 1501004B3758564D4201624F5512B197
[eMMC] : FLASH_EXT : 00400000/00080000
[eMMC] : FLASH_LEN : 0x00000001D2000000
INT RAM : 0x00020000
EXT RAM : 0x40000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Reading Flash Conent now ...
Brand : Cherry Mobile
ProdName : Flare S3
ProdModel : H870
Device : Flare S3
AndroidVer: 4.4.2
MTKxCPU : MT6582
MTKxPRJ : Cherry_Flare_S3_V1.03_V03_20140927
[Read Ok] : preloader_signal82_wet_kk.bin
[Read Ok] : MBR
[Read Ok] : EBR1
[Read Ok] : lk.bin
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : secro.img
[Read Ok] : logo.bin
[Read Ok] : system.img
[Read Ok] : cache.img
[Read Ok] : userdata.img
[ScatCFG] : MT6582 / V1.1.1 / signal82_wet_kk / EMMC
FW Size : 695 MiB
Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6582__Cherry Mobile__H870__Flare S3__4.4.2__Cherry_Flare_S3_V1.03_V03_20140927\
All done!
then remove virus using smart AV
Operation : Remove Viruses [SmartAV] [ v1.36 ]
Wait for phone...
Phone found! [ 17 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CB00
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
SmartAV Init Ok!
Scanning FileSystem now , please wait
Scan Done, infected files found : 1
Removing infected files and scripts ...
SmartAV Report : Removed 1 infected files!
Making additional operations ...
Special Op #1 : Clear Recovery Data Ok!
Special Op #2 : PostFix Ok!
Done!
Done!
Elapsed: 00:01:53
Reconnect Power/Cable!
then make full reset
Operation : Format FileSystem [ v1.36 ]
Wait for phone...
Phone found! [ 17 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CB00
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:18
The Following User Says Thank You to Ginerz For This Useful Post:
Old 11-13-2015, 10:00   #2 (permalink)
Member: 2485541
sir Ginerz tnx to ur info!also can i ask f the smart AV is built in or i need to download it?Godbless
Old 11-13-2015, 10:32   #3 (permalink)
Member: 1189220
Thanks Meter: 21
under EXTRA tab of CM2..try to explore=)
Old 11-13-2015, 11:10   #4 (permalink)
Member: 1166901
Sonork: Ginerz
Thanks Meter: 28
Old 11-13-2015, 11:38   #5 (permalink)
Member: 2485541
sir micoyo what u mean by extra tab of CM2?
Old 11-13-2015, 14:20   #6 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,628
Does it hard to look at picture?
The Following User Says Thank You to JayDi For This Useful Post:
Page generated in 0.23971 seconds with 7 queries
