Old 10-04-2009, 11:05   #1 (permalink)
Babyunlocker's Avatar
Member: 1104730
Thanks Meter: 431
cherry mobile
Cherry mobile Codes...
model:
D20= default code; 1122, TestCode : *#433979#
M35= default: 0000, Testcode: *#3226#
D50= default:1234, Testcode: *#8888#, sw version: *#8818#
D20
HOW TO RESET THIS
Old 10-04-2009, 11:17   #2 (permalink)
FullFLASHgSMPH's Avatar
Member: 161739
Sonork: 100.1584054
Thanks Meter: 3,337
software version: 1.19
cable type: 2x5 (L10C)
platform: MT: MT62xx (autodetect)
searching adapter at COM13...
adapter found, version: 2000
pins: 10, plain
power cycles: 1
activation cycles: 7
power-off delay: 20
start Rx/Tx: 1/1
Loading configuration...
Initializing...
Press and HOLD phone Power button now !
detecting pins...
19200 fixed
CPU: MT6223
result: Rx:3 Tx:4
time required: 12 sec
Trying to Power-On...
Power On !
try this TESTED
BR....
The Following User Says Thank You to FullFLASHgSMPH For This Useful Post:
Old 10-04-2009, 12:04   #3 (permalink)
Member: 1104730
Thanks Meter: 431
ROCK N ROLL SOLVED AND RESET
COM13 [VCP3] selected
module v2.91
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: "user code"
unlock method: standard
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:AF41:000C
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 01227E22202200:2BEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device rom info...
detection phase #1...
detect device rom info finished
rom info structure: 2nd [enhanced] generation
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.5DF72BC1.[HEDY23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.MAUI_08A _W08_28_V001_PL_25_60.BIN_00FDB2F4].rpl
New firmware detected (v.2.91, database date: unknown):
This firmware is missing in support area. If this phone is good and working:
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
device-id: 5DF72BC1
rom info protocol ver: 04
ver. sw 1: HEDY23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.MAUI_08A _W08_28_V001_PL_25_60.BIN
ver. sw 2: MAUI.08A.W08.28.V001.PL.25.60, 0B4D02FF
ffs offset/size: 00E00000/00200000
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
ffs/eeprom found near: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
detecting startup code area #2...
startup code area #2 is absent
detecting ffs/eeprom structure pass 1...
detect standard fat location pass #1...
detect standard fat offset pass #1...
detect standard fat location pass #2...
detect standard fat offset pass #2...
detect standard fat location pass #3...
detect standard fat offset pass #3...
detect standard fat location pass #4...
detect standard fat offset pass #4...
detect standard fat location pass #5...
detect standard fat offset pass #5...
detect standard fat location pass #6...
detect standard fat offset pass #6...
detect standard fat location pass #7...
detect extended fat location pass #7...
detect standard fat offset pass #7...
detect standard fat data...
fat layout detection complete
ffs/eeprom detected ok: element #1
startup code area #1 check...
startup code area #1 fixed
detect device sec info...
detect device sec info finished
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: HEDY23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.MAUI_08A _W08_28_V001_PL_25_60__ffs...
file saved: C:\Documents and Settings\GSM Baguio\Desktop\HEDY23C_08A_GEMINI_PCB01_GPRS_MT622 3P_S00.MAUI_08A_W08_28_V001_PL_25_60__ffs_20091004-185101.B0E.bin
Backup required data Done
Patch required data ...
detection procedure, wait...
detection procedure completed
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write: eeprom
Write Done
Finalization ...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\H EDY23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.MAUI_08A_ W08_28_V001_PL_25_60__system_log_5DF72BC1_00FDB2F4 _20091004-185319.B0X.bin
Finished, time used: 450 sec
Remove/Install battery now !
The Following User Says Thank You to Babyunlocker For This Useful Post:
Old 05-28-2010, 09:55   #5 (permalink)
Member: 619463
Thanks Meter: 20
br i wand d20 eerom file
Old 05-28-2010, 11:54   #6 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 32,669
Hello,
What is "D20" ?
What is required firmware version ?
Old 11-03-2010, 11:17   #7 (permalink)
Member: 448210
Thanks Meter: 4
module v2.91
Action: "user code"
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: FF
Boot Done
Initialize ...
Initialize Done
Set baud ...
115200
Set baud Done
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
device-id: 5DF72BC1
ffs/eeprom chip: 00
Write ...
Write: eeprom
Write Done
Finalization ...
Finalization Done
i need this firmware for d20 cherry mobile,tia
Old 11-04-2010, 10:49   #8 (permalink)
YellowBoss's Avatar
Member: 1043909
Thanks Meter: 42,598
Please, download file from Infinity-Box support area:
\flashfiles\ChineseMiracle\_MT6223\HEDY23C_08A_GEM INI_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_28_V001_PL _25_60__Cherry-Mobile-D20_16m_En_Cn.B0M.bin
Old 07-28-2012, 11:28   #9 (permalink)
Member: 1790600
how about cherry mobile w2 . what was the factory reset code?
Old 12-11-2013, 01:16   #10 (permalink)
Member: 1728494
thanksssssssssssssssssssssss
Pls Support these Phones - Cherry Mobile Rabatu Infinity-Box 6 07-22-2012 03:05
cherry mobile 1800 needed help andy_lecnah Infinity-Box 4 03-28-2010 04:52
Cherry Mobile is it supported? jr astigin Infinity-Box 2 02-19-2010 11:23
How to use infinity in servicing cherry mobile baywalker Infinity-Box 2 02-07-2010 10:14
Powered by Searchlight © 2017 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2015 -
Page generated in 0.38442 seconds with 8 queries
