cherry mobile astro dead after flash hello team yesterday i have astro pattern problem i try to read boot https://z-1-scontent-sea1-1.xx.fbcdn...d2&oe=578B48B1 i decide to flash because i have backup from other phone here logs https://z-1-scontent-sea1-1.xx.fbcdn...43&oe=57BD9C97https://z-1-scontent-sea1-1.xx.fbcdn...ee&oe=578BE601 but phone is dead but i see other phone version not same from my backup that's why he kill my phone check my phone picture here and check version https://z-1-scontent-sea1-1.xx.fbcdn...dd&oe=5774F613 https://z-1-scontent-sea1-1.xx.fbcdn...fa&oe=578AD898 https://z-1-scontent-sea1-1.xx.fbcdn...c8&oe=577BD79C can you revive my phone team or any idea what can i do:confused: |
Hello. You need readout FW from same version HW phone. I will check about NAND versions. |
Yes I found same unit and version but the problem is I can't read the firmware can't boot show like my 1st post picture |
hello team still waiting for solution. pls help us |
Kabayan, cherry mobile astro with two types of firmware b128k and b256k i think the one astro dead, you flash with b256k firmware. |
ah i see OT: baka my stock rom ka jan kabayan pwde pag usapan natin yan :D |
STILL WAITING Operation : Check/Read Info [ v1.17 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 51 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader NAND v1.1 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! Unknown structure detected! Check correct model selection! Elapsed: 00:00:50 Reconnect Power/Cable! |
need this solution too... i got same problem with you boss marvz... up for this |
to solve this kind of problem, follow carefully this instruction first, remove battery and reinsert it back to the phone. second (TIME INTERVAL IS VERY IMPORTANT) press and hold power button and AFTER 1 SECOND INTERVAL press and hold volume up and wait till the logo appears... when the logo appears COUNT 2 SECOND release both power and volume buttons.. WAIT..... A COMMAND PROMPT WILL APPEAR AND SELECT RESTORE FACTORY SETTINGS..AND GO ON.. BUT IN SOME CASES that wont work. so if that method doesnt work then go back to setting and enable usb debugging (toggle down notification bar and navigate setting) now that you have enabled usb debugging, coonect your cp to your pc..wait till the drivers are installed... open uni-android tool set-up from your pc and select "reboot to recovery" and hit enter..(you can use any android tool that has a rebbot-to-recovery function) your phone now will reboot to recovery mode..and you know what to do |
