10-24-2015, 10:08 | #1 (permalink) |
No Life Poster Join Date: Feb 2001 Location: PH
Member: 3468 Status: Offline Thanks Meter: 308 | Cherry Mobile Flare 4 Privacy Lock Problem i have cherry flare 4 with privacy protection, already reset privacy lock but phone stil ask code.reset user lock and full factory reset phone still ask code Read Phone Info Operation : Check / Read Info [ v1.34 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 126 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6753 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6753_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 524E011336394A31C479104E174D3745 DA Stat : v4.2 on BBID : 0x93 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0013 , OEM : 014E [eMMC] : FLASH_INF : N69J1 [eMMC] : FLASH_CID : 13014E52314A39364E1079C445379217 [eMMC] : FLASH_EXT : 00400000/00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Cherry ProdName : FLARE4 ProdModel : FLARE 4 Device : CherryMobile AndroidVer: 5.1 MTKxCPU : MT6735 MTKxPRJ : Cherry-Mobile-Flare-4-V09-09182015 Operation : Reset Privacy Lock [ v1.34 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 126 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6753 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6753_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 524E011336394A31C479104E174D3745 DA Stat : v4.2 on BBID : 0x93 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0013 , OEM : 014E [eMMC] : FLASH_INF : N69J1 [eMMC] : FLASH_CID : 13014E52314A39364E1079C445379217 [eMMC] : FLASH_EXT : 00400000/00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Checking data ... Privacy Lock reset Ok! Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to Rex For This Useful Post: |
10-24-2015, 10:20 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Thanks for the info. I miss to check that on 6735/53 series. New version will be after 1-2 hour. With UserData Safe and forced mode. |
