02-19-2016, 01:49 | #1 (permalink) |
Freak Poster Join Date: Sep 2011 Location: philippines
Member: 1649546 Status: Offline Thanks Meter: 123 | CHerry MOBILE FLARE S4 MONKEY VIRUS DONE Chinese Miracle II [MTK module] v 1.41 Operation : Scan APPs [DDirect] [ v1.41 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D3332380A950042E133CED8 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM328 [eMMC] : FLASH_CID : 150100513832334D4200950AD8CEA2E1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 8A54C01208E6C8F46349F82286E78E98 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! DDirect : Init Ok! Scanning FileSystem now , please wait Collect and verify data according Dictionary Nothing found! [DDCleaner Info] : Files to remove : 1 [DDCleaner Info] : Additional garbage detected : 1 Removing files ... [DDCleaner] : Removed 1 Special Op #1 : Clear Recovery Data Ok! Special Op #2 : Clear UserData Ok! Special Op #3 : PostFix Ok! All Done! Done! Elapsed: 00:00:44 Reconnect Power/Cable! Operation : Remove Viruses [SmartAV] [ v1.41 ] SmartAV Conf : 100/80/2000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D3332380A950042E133CED8 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM328 [eMMC] : FLASH_CID : 150100513832334D4200950AD8CEA2E1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 8A54C01208E6C8F46349F82286E78E98 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 1 Removing infected files and scripts ... SmartAV Report : Removed 1 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #3 : PostFix Ok! Done! Done! Elapsed: 00:00:46 Reconnect Power/Cable! |
