01-06-2011, 15:15 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Afrique du sud Age: 42
Member: 430612 Status: Offline Thanks Meter: 301 | china 5130 formating ok but still dead module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:5CA7:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22102201:2AEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #01 in region #00... flash: 01227E22102201:2AEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #02 in region #00... flash: 01227E22102201:2AEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #03 in region #00... flash: 01227E22102201:2AEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #04 in region #00... flash: 01227E22102201:2AEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #05 in region #00... flash: 01227E22102201:2AEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #06 in region #00... flash: 01227E22102201:2AEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #07 in region #00... flash: 01227E22102201:2AEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 number of flash chip/regions detected: 08/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E22102201:2AEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #01 in region #00... flash: 01227E22102201:2AEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00700000 standard ffs/eeprom offset confirmed: 00700000 detecting ffs/eeprom size... ffs/eeprom size: 00100000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00700000-007FFFFF firmware area: 00000000-006FFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: _ffs... file saved: C:\Program Files (x86)\InfinityBox\ChineseMiracle\_ffs_20110106-161015.B0E.bin flash: 01227E22102201:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E22102201:2AEA0000000000 Finalization Done Finished, time used: 2 min 18 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
01-06-2011, 18:43 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! yes, firmware is damaged. you must flash it. to get know correct flash file version best way is to search for short version code printed on PCB. It is usually located near LCD or under it. here is example how it should look like: http://forum.gsmhosting.com/vbb/6714619-post4.html |
how to unlock 5130 | accelr8 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-24-2010 17:52 |
6110 unlocked but wont give reception | KingOfKingston | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 04-10-2000 22:15 |
5130 5190 6190 | MGG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 04-03-2000 20:36 |
Still with nokia 5110 ver 5.24 | VirtualM | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 11-11-1999 18:57 |
DOES THE CELLNET DIGA HACK STILL WORK??? | SP UNLOCKER 2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-04-1999 13:55 |
