03-28-2009, 19:29 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 49
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks Meter: 1,212 | <<< China A666 Touchscreen Calibration Failed >>> calibration , pinouts successfull defines in pinfinder with L12c cable, now i make full flash & eeprom for your test , please test this file & support me urgent , thanks in advance. http://www.4shared.com/file/95484137...130628B0M.html Full Flash & Eeprom Here ::::::Logs:::::: COM5 [VCP0] selected module v2.79 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read ffs/eeprom Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:A603:0004 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #02 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #03 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation ==================== New firmware detected (v.2.79, database date: 24.03.2009): PROWAVE25_GEMINI_PCB01_GPRS_MT6225_S00.LT526B_R1_0 _39_3.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: PROWAVE25_GEMINI_PCB01_GPRS_MT6225_S00.LT526B_R1_0 _39_3.BIN ver. sw 2: LT526B_R1.0.39.3, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98004900000002:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[PROWAVE25_GEMINI_PCB01_GPRS_MT6225_S00.LT526B_R1_0 _39_3.BIN]... file saved: C:\Documents and Settings\Administrator\Desktop\chinachina\eeprom[PROWAVE25_GEMINI_PCB01_GPRS_MT6225_S00.LT526B_R1_0 _39_3.BIN]_20090328-131508.B0E.bin Finished, time used: 298 sec Remove/Install battery now ! :::::::: touchscreen calibration failed LOG :::::::: COM5 [VCP0] selected module v2.79 Action: touchscreen calibration mode: 5 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:A603:0004 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: LT526B_R1.0.39.3 Version: PROWAVE25_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 3565777777777777 connection Ok detecting structure #5 (mode-5)... 0 1 2 done 209 byte(s) read writing data... verification... error: verification failed Finished, time used: 18 sec Remove/Install battery now ! |
The Following User Says Thank You to khadim100 For This Useful Post: |
04-04-2009, 11:41 | #2 (permalink) |
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks Meter: 1,212 | infinity team , this phone is tested or in under testing??? i am waiting your reply because i have one mobile with touchscreen calibartion fault. |
<<< Chinese Miracle 2.91 Touchscreen Calibration Improvement >>> | khadim100 | Infinity-Box | 1 | 10-02-2009 07:33 |
<<< Chinese Miracle 2.91 Touchscreen Calibration Improvement >>> | khadim100 | Infinity-Box | 0 | 09-30-2009 17:02 |
Ztc N328 touchscreen calibration failed | KK Mobile | Infinity-Box | 1 | 05-06-2009 20:20 |
Touchscreen calibration failed in N99i | lie_james | Infinity-Box | 1 | 01-23-2009 19:40 |
subject: touchscreen calibration failed : New firmware detected (2.70) | Faisal_Computer | Infinity-Box | 1 | 12-06-2008 13:57 |
