china android imei invalid hi , i have problem with repair imei china android phone mt65XX i try to repair with blutood metod but without lucky anybody help me |
solved ............. the theme is closed |
How did you solved this problem? |
echo 'AT+EGMR=1,7,"IMEI_1"' >/dev/pttycmd1 echo 'AT+EGMR=1,10,"IMEI_2"' >/dev/pttycmd1 |
1 Attachment(s) term.apk download ;) solution work fine |
Another way First need get root with this program: SuperOneClick We go on this link. We enter both IMEI in a form, we press the button "Continue". Receiving message "Everything is OK. File created", we press "Download" for the flush-off of the generated file. It is possible to get from a phone. Further we place a file into fixed place, with terminal on phone this comand (cp /sdcard/MP0B_001 /data/nvram/md/NVRAM/NVD_IMEI), and we reboot a phone. Attention! An On-line-generator does not work with one IMEI, entering is needed both! |
nice works keep up guys goodluck |
here is example for IMEI 123456789012345: echo 'AT+EGMR=1,7,"123456789012345"' >/dev/pttycmd1 this command in terminal window can be copy>pasted or written by hand |
easy way use adb shell on pc call su accept on phone then write command with keyboard |
ice movile shine imei i have a ice movile shine with imei damage i nedd to restore imei itīs a amdroid phone please help |
try with term.apk, as was advised above |
I do not have more information on this subject alone, I need mt65xx USB Port Driver would be glad if you help me in this regard .. |
China Android Imei Change No Need Box No Need Cable Hello, Many Times This Command Not Accepted(echo 'AT+EGMR=1,7,"123456789012345"' >/dev/pttycmd1) So Don't Worry Here Is Another Command For Perform Operation..........:) Install Term.apk In Your Device Then Run It & Write This Command By Your Hand..........:) echo AT+EGMR=1*7*IMEI_1 >/dev/pttycmd1 echo AT+EGMR=1*10*IMEI_2 >/dev/pttycmd1 Hope It Will Work For You If Any Problem PM Me.................... Regards, |
hello bro.... this code not wokig me .... my mobile clome samsung gt-i9082 mtk 6575 and android ver. 4.2.2 phone buy from bancock please help .. thanks ... :) |
