09-09-2008, 06:09 | #1 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 306026 Status: Offline Thanks Meter: 111 | China apple iphone 8gb but infinity can read the firmware of this phone Connecting, wait... Initializing[6230:8A02:8A02]... CPU: MT6230 high speed boot enabled chip: 0031:2002:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.020C loader: 3.748.0 NAND id: ECF10095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 NOR: 0000:000000000000 [00000000] NAND: 00EC:00F100000095 [08400000] NOR chip is not installed Initialize Done Set baud... 921600 Set baud Done Identification... reading structure area... error: unexpected answer: F7 error: page confirmation is absent, possible data loss ! detecting structure... warning: bootloader absent: 424F4F544C4F41444552210056303035 nfi area detection finished: failed error: can't detect nand chip parameters, default values assigned error: can't detect ffs address Read full flash instead of firmware ! Finished, time used: 38 sec Remove/Install battery now ! |
09-09-2008, 07:03 | #2 (permalink) |
Member: 306026 Status: Offline Thanks Meter: 111 | with 460800 speed Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6230:8A02:8A02]... CPU: MT6230 high speed boot enabled chip: 0031:2002:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.020C loader: 3.748.0 NAND id: ECF10095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 NOR: 0000:000000000000 [00000000] NAND: 00EC:00F100000095 [08400000] NOR chip is not installed Initialize Done Set baud... 460800 Set baud Done Identification... reading structure area... error: unexpected answer: error: page confirmation is absent, possible data loss ! detecting structure... source data: page+spare converting data... done 0x00080000 bytes identification#1 protocol ver: 04 ver. sw1: UFO318_B_PCB01_GPRS_MT6230_S02.APL216_A_V1_2_20080 529.BIN ver. sw2: APL216_A_V1.2_20080529, 0F919E51 ffs offset/size: 02000000/06000000 id-page1 Ok nfi area detection finished: Ok identification#1 structure: 2nd [enhanced] generation error: unexpected answer: 01 error: page confirmation is absent, possible data loss ! error: unexpected answer: 61 warning: nfi read command is not accepted error: can't read security area#1 reading... error: unexpected answer: 00 warning: nfi read command is not accepted warning: probably errors exist during flash read operation Finished, time used: 522 sec Remove/Install battery now ! |
01-29-2009, 14:57 | #4 (permalink) |
Freak Poster Join Date: Apr 2006
Member: 263709 Status: Offline Thanks Meter: 327 | Unable to flash Even with the lower speed.. Need solution.. baud autodetection active 19200 autodetect Connecting, wait... Initializing [6230:8A02:8A02]... CPU: MT6230 high speed boot Off chip: 0031:000B:0101 high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.020C loader: 3.748.0 NAND id: ECF10095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 NOR: 0000:000000000000 [00000000] NAND: 00EC:00F100000095 [08400000] NOR chip is not installed Initialize Done Set baud ... 115200 Set baud Done Identification ... reading structure area... detecting structure... warning: probably flash chip completely erased, no bootloader found nfi area detection finished: failed error: can't detect nand chip parameters, default values assigned security area (code #1) calculation... Identification Done Write ... error: unexpected answer: error: incorrect write core parameters error: can't write nand core Write Fail Finished, time used: 131 sec Remove/Install battery now ! |
01-31-2009, 14:36 | #9 (permalink) |
Member: 263709 Status: Offline Thanks Meter: 327 | Thx for quick Reply... Original File: APL216_PCB01_GPRS_MT6230_S02.APL216_V1_1_20080910. BIN]_full_20090129-170826.B4M I got a warning "nand_probably_damaged" When making backup.. Back file is uploaded here.. http://rapidshare.com/files/19202606...-170826.B.html And flashed with "APL216_PCB01_GPRS_MT6230_S02.APL216_V1_2_20080918 _128m_En_Ru_Fr_Farsi_Ar.B4M" From support area.. Last edited by basilbaby; 01-31-2009 at 14:44. |
02-02-2009, 11:47 | #11 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! unfortunately, file names "probably damaged" are not valid backups. they contain errors and can not be used neither for flashing nor for language editing. same version good flash file must be found in order to repair your faulty phone. but i must warn you that this search might be usless, because due 6228 MCU unstable work most problems with this type of phones are not software related. So, 90% that even if you find good flash file- this will not repair your phone |
02-02-2009, 17:45 | #13 (permalink) |
Member: 306026 Status: Offline Thanks Meter: 111 | to make a good backup with infinity try to use spiderman pin finder as a cable and use infinity chinese miracle to read full flash. it will works smooth i have a bad experience with other pin finder, when i try with spiderman it works and no more worry about read error or else. i heard u try it with infinity finder and still error occur, my first attempt is with paklink and always error. 1.search phone with spiderman 2.open chinese miracle and set the comport to spiderman port 3.read software/flash/format etc |
02-02-2009, 18:07 | #14 (permalink) |
Member: 263709 Status: Offline Thanks Meter: 327 | http://rs245.rapidshare.com/files/16...hina_copy_.rar This is a backup from working phone in bin format. the file is 132mb in size.. Can u please upload this file to support..? Or can i flash bin file? |
