Old 05-19-2009, 12:36   #1 (permalink)
unlock & flash's Avatar
Member: 745728
Sonork: 100.1579942
Thanks Meter: 338
china bluetooth fm flash file need.
cpu-6225
port-L10C
here is image
pls help me argently
Old 05-19-2009, 13:39   #2 (permalink)
biochemistali's Avatar
Member: 190344
Thanks Meter: 267
what is the file name.?
did u try format ffs in safe mode?
what was the fault in set.?
what is the condition of mobile now?
br
hamid
Old 05-19-2009, 15:15   #3 (permalink)
Member: 745728
Sonork: 100.1579942
Thanks Meter: 338
set is dead after format with spiderman
i dont know what is original frimware version
Old 05-19-2009, 17:50   #4 (permalink)
Member: 745728
Sonork: 100.1579942
Thanks Meter: 338
module v2.81
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: "format ffs"
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:7E03:0004
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
Warning: probably flash chip is empty, erased, incorrectly flashed or damaged !
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box UN-CHECKED !
3. make flash write operation
If still no luck: send mail to support ([email protected]) with detailed description of problem,
attach the next files in your e-mail:
1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log
2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin
it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
detect device identification#2 finished
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset assigned: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
Finished, time used: 106 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
here is log after dead when i try to format with infinity
Old 05-19-2009, 21:59   #5 (permalink)
Member: 148515
Thanks Meter: 16,255
hello!
whole flash is erased.
only someone, who know this model can advice flash file
Old 05-20-2009, 05:48   #6 (permalink)
Member: 745728
Sonork: 100.1579942
Thanks Meter: 338
hello!
this model is very uncommon.thats why i faced little problem .
Need china 6300 d flash file need sajjadahmad Infinity-Box 1 08-11-2009 22:02
need motorolla c117 bluetooth fm flash file mbiborna Chinese Models & Cloned Phones 1 05-24-2009 09:05
china bluetooth fm flash file need. unlock & flash Chinese Models & Cloned Phones 6 05-20-2009 07:31
need china bluetooth fm flash file unlock & flash SpiderMan 1 05-20-2009 05:48
China bluetooth a5 flash file needed SHIJILFONOTLY Infinity-Box 0 10-31-2008 05:51
Page generated in 0.31721 seconds with 9 queries
