Old 04-07-2011, 10:45   #1 (permalink)
Member: 1108022
Thanks Meter: 32
China flash file
Hi Infinity team.
I got the flash file for my phone but is not infinity format.
Can you help me ti get the infinity format version
Page_with_Spare.zip
Thanks
Old 04-07-2011, 19:13   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
here it is:
http://rapidshare.com/files/45636254...22E_CW.B0M.bin
Old 04-08-2011, 11:47   #3 (permalink)
Member: 1108022
Thanks Meter: 32
Hi, I can't write back the firmware:
COM32 [VCP0] selected
module v3.29
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: write flash
write: Firmware
S3504_PCB01_GPRS_MT6235B_S01.ZMP_QT_CN_OV_HY512_12 22E_CW.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6235:8B00:8A01]...
CPU: MT6235
high speed boot On
chip: 0000:0000:0003
status: FF
boot packet size: 0400
Release Power button now !
in case of initial connection problem: on/off "Boot baudrate autoselect"
Boot Fail
Finished, time used: 15 sec
Remove/Install battery now !
Old 04-08-2011, 11:55   #4 (permalink)
Member: 1108022
Thanks Meter: 32
Are you sure this is a good Infinity type file? Because for NAND I can't load it.
Please check it from your side.
Thanks
Old 04-08-2011, 18:29   #5 (permalink)
Member: 1108022
Thanks Meter: 32
The flash you provided is wrong, not a NAND file. Please assist.
Thanks
Old 04-08-2011, 19:41   #6 (permalink)
Member: 1108022
Thanks Meter: 32
Phone is dead after I have uploaded that file.
Hope we can resolve this problem, the infinity caused problem for us.
Old 04-09-2011, 09:26   #7 (permalink)
Member: 148515
hello!
sorry, it must be renamed to .B4M. instead of B0E.
regarding unswitchable phone: i only converted it, i can not guarantee this file functionality
Old 04-09-2011, 10:59   #8 (permalink)
Member: 1108022
Thanks Meter: 32
I have saved the before the firmware and now still not working the phone.
Old 04-11-2011, 10:10   #9 (permalink)
Member: 1108022
Thanks Meter: 32
Is there any too which is converting BIN to Infinity file format?
Also Can you add into Infinity Format the page and the Spare?
Old 04-11-2011, 12:26   #10 (permalink)
Member: 148515
hello!
coverter is not for public release.
regarding your writing problem.
have you finally set CPU type to NAND before writing backup?
can you post flashing log?
Old 04-11-2011, 17:30   #11 (permalink)
Member: 1108022
Thanks Meter: 32
==== [2011-04-10 11:27:34] ====
module v3.29
Device: Autodetect 6228-6268 NAND
Action: write flash NAND
write: Firmware
S3504_PCB01_GPRS_MT6235B_S01.ZMP_QT_CN_OV_HY512_12 22E_CW..B4M.bin
skip: Customization
skip: Eeprom/ffs
nfi area detection...
converting data...
done 0x04000000 bytes
bootloader version: S3504_BOOTLOADER_V005_MT6235B_ZMP_QT_CN_OV_HY512_1 222E_CW.bin
nfi area detection (3 cores) finished: Ok
interface: BROM_DLL_v3.1016.00
Connect...
Connecting...
Booting...
bootcode current/expected: 3.2/3.2
CPU: 6235:8B00:8A00
status: FF
bbchip bl ver: FE
NOR flash chip: not installed
NAND flash id[001E]: 0020:007600200076 [ST] ST512W3A
chip size: 64Mb
page/spare size: 0200/0010
pages per block: 0020
bits i/o: 08
address cycles: 04
internal RAM size: 00010000
external RAM: S_DA_RAM_ERROR
done
Set baudrate (230400)...
done
interesting cpu type found: 6235:8B00:8A00
ram test...
testing 32bit...
32bit ram test passed
testing 16bit...
16bit ram test passed
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 02000000/02000000
firmware size: 32Mb
ffs size: 32Mb
detect sec ro...
detect custom parameters...
detect project-id...
project-id: ZMP_QT_CN_OV_HY512_1222E_CW
detect NAND info...
number of areas/bytes to read: 1:00034000
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
warning: id-page1 area is invalid
nfi area detection (0 cores) finished: failed
warning: ffs can not be detected
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
startup code area #1 detection done
rom info ver: 07
sw version: S3504_PCB01_GPRS_MT6235B_S01.ZMP_QT_CN_OV_HY512_12 22E_CW.BIN
project-id: ZMP_QT_CN_OV_HY512_1222E_CW, 00000000
code offset: 00000000
rom info structure: [standard] type (07)
TCL-ID is absent
===> done
New firmware found (v.3.29, database date: 04.04.2011):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
converting data...
startup code area #1 check...
done
number of cores: 3
loading files...
number of areas: 3
done
write...
write bootloader...
write core...
Disconnect...
done
Finished, time used: 26 min 9 sec
Old 04-12-2011, 19:04   #12 (permalink)
Member: 148515
hello!
flashing log is perfectly Ok.
i think your flash file was read from non working phone or your phone has damaged hardware. I dont see other reason for this
Old 04-13-2011, 13:59   #13 (permalink)
Member: 1108022
Thanks Meter: 32
in this case waiting for a working S3504_PCB01_GPRS_MT6235B_S01.ZMP_QT_CN_OV_HY512_12 22E_CW.BIN
Old 04-13-2011, 14:15   #14 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Already present on support area-
flashfiles/1MTK/_MT6235/S3504_PCB01_GPRS_MT6235B_S01.ZMP_QT_CN_OV_HY512_12 22E_CW_En_Fr_Es_Pl_Pt_Magyar_De_Ml_Id_Cz_Nl_Tr_Vn_ Ru_Persian_Gr_Cn_2010-12-22.B4M.bin
Just download it from support area.
Wr.
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 19:37
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
how can we use *.scr files to unlock shadow77 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-27-1999 03:13
Page generated in 0.19916 seconds with 9 queries
