Old 11-16-2008, 06:27   #1 (permalink)
dharmeshslnk's Avatar
Member: 385162
Thanks Meter: 598
China flash file(infinity support)
Hi
Sir i have china phone(model-CBP 571) i need flash file please help me.i attached file opration.log plese give me file.
i am waiting for your anwer.
==== log opened: [11/16/2008 10:36:38 AM] ====
Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e
Loading data, wait...
[Infinity Box] v2.66
S/N: 2778:0111
Wait...
Device: Autodetect 6205-6227 NOR
Done
COM8 ready
COM7 ready
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
Do you want to continue ?
==== log: [11/16/2008 10:37:04 AM] ====
COM7 [VCP0] selected
module v2.66
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: "format ffs"
Boot...
19200 fixed
Connecting, wait...
Initializing[6219:8B02:8B01]...
CPU: MT6219
high speed boot enabled
CPU: MT6226MA detected
chip: 0031:B341:415C
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 01227E223C2200:FFFFFF00000000
flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
Warning: probably flash chip empty, erased, incorrectly flashed or damaged.
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box UN-CHECKED !
3. make flash write operation
If still no luck: send mail to support ([email protected]) with detailed description of problem,
attach the next files in your e-mail:
1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log
2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin
total flash region size: 02000000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset assigned: 01000000
checking area[00000000]: 00000000-01FFFFFF...
Can't detect eeprom/ffs area
Do you want to use standard ffs address: 01000000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
operation terminated by user
error: critical error#1 during ffs size detection
error: can't detect eeprom/ffs address/size
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
Finished, time used: 56 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
phone is dead
The Following 2 Users Say Thank You to dharmeshslnk For This Useful Post:
Old 11-16-2008, 10:38   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
There is no any information about phone firmware in your log.
Flash chip is completely erased or damaged.
I suggest you to check pictures in support area and try to find similar firmware: \flashfiles\ChineseMiracle\_doc\pictures
Old 11-17-2008, 06:20   #3 (permalink)
Member: 385162
Thanks Meter: 598
Thanks for reply but there no picture in support area i upload picture please give me flash file
http://rapidshare.com/files/16453589...08015.jpg.html
http://rapidshare.com/files/16453589...08016.jpg.html
http://rapidshare.com/files/16453589...08017.jpg.html
http://rapidshare.com/files/16453589...08018.jpg.html
http://rapidshare.com/files/16453589...08019.jpg.html
http://rapidshare.com/files/16453589...08020.jpg.html
Old 11-17-2008, 20:25   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
this model is unknown for me, cant advice any flash file.
maybe some of forum members will help us?
6670 china flash in support GRAVE_DIGGER Twisterflasher 0 02-22-2005 00:52
T610 china flash > infrared problem ckkckk Sony Ericsson 0 02-05-2005 10:29
NEED 3650 china flash with ppm LORD_SHAH WD2 & APE (Symbian Phones) 7 07-26-2004 14:24
E600 China flash wanted Tapsi Jr SYSOL Platform 8 07-16-2004 21:34
need t68ie china flash segsm Sony Ericsson 0 05-20-2003 03:16
Page generated in 0.17860 seconds with 9 queries
