12-12-2010, 13:26 | #1 (permalink) |
Freak Poster Join Date: Apr 2006 Location: EARTH
Member: 259397 Status: Offline Thanks Meter: 76 | china fone stuck on user code . cpu 6205 user code .. i alos read code .. and format ffs and flash from support aria (CM_Nokia-N77i-2sim_CKT_NEPC06A_PCB01_GSM_MT6205B_DN.SWAN+_6205_G Y_223_070817_SP53_4m_En.B0M.bin but.. mobile is still in userlock code.... here is read flash file from fone . CKT_NEPC06A_PCB01_GSM_MT6205B_DN.SWAN+_6205_GY_223 _070817_SP53__firmware_part_1_of_1_20101212-170419.B0M.bin plz infinty support how can i solve this prob |
12-13-2010, 08:03 | #3 (permalink) |
Member: 259397 Status: Offline Thanks Meter: 76 | thnx .. a lot ... infinity team.... yes ... i find master cpu pinout and rest user code... sucessfully done . COM6 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "user code" unlock method: standard fast ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:FD7A:15E6 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2CEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:2CEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: 98004900000002:2CEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: 98004900000002:2CEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98004900000002:2CEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:2CEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 it's time to stop: 2C0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.CC450824.[CKT26_06B_PCB01_GPRS_MT6226_S01.SWAN+_6226_YTCQYR_ LSM_224_070818_LD0_0V0_SA75_CTF_BT.BIN_850B2751].rpl rom info detection finished device-id: CC450824 rom info ver: 04 sw version: CKT26_06B_PCB01_GPRS_MT6226_S01.SWAN+_6226_YTCQYR_ LSM_224_070818_LD0_0V0_SA75_CTF_BT.BIN project-id: SWAN+_6226_YTCQYR_LSM_224_070818_LD0_0V0_SA75_CTF_ BT, 51270B85 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98004900000002:2CEA0000000000 checking area [00000000]: 00080000-00FFFFFF... ffs/eeprom found near: 00E30000 Detected ffs/eeprom address is non-standard: 00E30000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 00E30000 detecting ffs/eeprom size... ffs/eeprom size: 001D0000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E30000-00FFFFFF firmware area: 00000000-00E2FFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent detecting ffs/eeprom structure pass 1... ..................... ffs/eeprom: detect std location pass #1... .................................................. ....... ffs/eeprom: detect ext location pass #1... .................................................. ... ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 98004900000002:2CEA0000000000 Backup required data Done ====> Patch required data ... .................................................. ... lock area found Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 98004900000002:2CEA0000000000 flash: 98004900000002:2CEA0000000000 Write: lock-area-1 Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\C KT26_06B_PCB01_GPRS_MT6226_S01.SWAN+_6226_YTCQYR_L SM_224_070818_LD0_0V0_SA75_CTF_BT__system_log_CC45 0824_850B2751_20101213-120052.B0X.bin Finished, time used: 1 min 58 sec Remove/Install battery now ! |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
PIN1/PIN2 CODE | Jon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-26-2012 04:40 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
