06-05-2015, 10:51 | #1 (permalink) |
No Life Poster Join Date: Jul 2002 Location: sri lanka Age: 39
Member: 13932 Status: Offline Sonork: 100.1609876 Thanks Meter: 411 | china i9500 mt6572 hang after format.. Code: Operation : Check / Read Info [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 164 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 45010053454D30344728341F50EF9093 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0045 , OEM : 0100 [eMMC] : FLASH_INF : G40ME [eMMC] : FLASH_CID : 45010053454D30344728341F50EF9093 [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : alps ProdName : GT-I9500 ProdModel : GT-I9500 Device : GT-I9500 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1.2 Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
06-05-2015, 13:58 | #3 (permalink) |
Member: 13932 Status: Offline Sonork: 100.1609876 Thanks Meter: 411 | still hang after fix DL.. Code: Chinese Miracle II [MTK module] v 1.21 Operation : Fix DL Errors [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 164 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 45010053454D30344728341F50EF9093 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0045 , OEM : 0100 [eMMC] : FLASH_INF : G40ME [eMMC] : FLASH_CID : 45010053454D30344728341F50EF9093 [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
06-08-2015, 06:18 | #10 (permalink) |
Member: 13932 Status: Offline Sonork: 100.1609876 Thanks Meter: 411 | log of read Factory Firmware.. Code: Operation : Read Flash [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 164 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 45010053454D30344728341F50EF9093 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0045 , OEM : 0100 [eMMC] : FLASH_INF : G40ME [eMMC] : FLASH_CID : 45010053454D30344728341F50EF9093 [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : alps ProdName : GT-I9500 ProdModel : GT-I9500 Device : GT-I9500 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1.2 [Read Ok] : preloader_lightning89_wet_jb3.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Error] : Bad EXT data Looks like unusable file , break! Read Ok , collect info Brand : alps ProdName : GT-I9500 ProdModel : GT-I9500 Device : GT-I9500 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1.2 File conversion error, file already exists! Saved as default! Done! Elapsed: 00:03:14 Reconnect Power/Cable! |
06-09-2015, 12:24 | #14 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | There is something wrong with eMMC partitions or modified storage sizes. Will make a fix. In some near version will make it in one button. Working on that now. |
