05-22-2009, 15:26 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ropar
Member: 358277 Status: Offline Thanks Meter: 476 | s-90 flash write error module v2.81 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:F503:0000 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation ==================== New firmware detected (v.2.81, database date: 01.05.2009): A200_PCB01_GPRS_MT6225_S00.V06_ENFRARRUSPPTPEVITR_ AL.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: A200_PCB01_GPRS_MT6225_S00.V06_ENFRARRUSPPTPEVITR_ AL.BIN ver. sw 2: A200.V06.EnFrArRuSpPtPeViTr.AL, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Area: Eeprom/ffs flash: 2088C4FFFFFFFF:2088C400000000 Write: Eeprom/ffs error: no any expected answer error: flash write error: 00F00000:00002000 error: no any expected answer error: flash write error: 00F00000:00002000 detect device identification#2... detection phase #1... error: unexpected termination/freez: 00000000 detect device identification#2 finished Write Fail Finished, time used: 145 sec Remove/Install battery now ! set was dead by mistake set removed during formating. after too much search i found a set with same flash file i read both eeprom & firmware then i write this file in it but at 93% it is giving error .i have clean board reheat flash chip. error is same plz give me solution i m too much confused for this. |
05-24-2009, 11:08 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If flash can not be written it may be that flash chip is damaged or bad soldered. Try to reball flash chip or at least Heat it. Last edited by InfinityHelp; 05-24-2009 at 20:44. |
01-13-2010, 10:08 | #3 (permalink) |
Freak Poster Join Date: Jul 2006 Location: Pakistan
Member: 313337 Status: Offline Sonork: 100.1582697 Thanks Meter: 106 | when you write new flash files on infinity box.these things are to keep in mind. 1. when you flash new firmware, ffs is disturbed.then you format that on standard address.after flash complte when you will format the address will be selted and format will go on. 2. during flash or format some mobile required to press power button till at the end of completion.when you leave the power buttton flashing or format stopped with different errors depend upon the process running. 3. during format or flash when ever you cable is discocected or power is disturbed, infifity process show the wanings with errors and retry for some time , if you press and keep the power ON buttong, it will recover the error during the process and continue further at right direction. judge your self, which point guide you All above procedures are my own experience. So use with your risk |
02-13-2010, 10:03 | #4 (permalink) |
Freak Poster Join Date: Jul 2005 Location: everywhere
Member: 159105 Status: Offline Thanks Meter: 60 | sam probeme i have sam problem with many phone search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: 98006F00000004:18E59F00000000 Write: Firmware error: error# 000000FF error: flash write error: 00000000:00002000 2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC 2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC 2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC 2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC 2E3B3B3BFC2E3B3B3BFC2E3B3B3BF42E3B3B3BFC2E3B3B3BEC 2E3B3B3BF62E3B3B3BBA1A2E3B3B3BFC2E3B3B3BFC2E3B3B3B FC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3B FC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3B FC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3B FC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3B FC2E3B3B3B error: write operation failed Write Fail Finished, time used: 4 min 32 sec Remove/Install battery now ! |
02-14-2010, 09:20 | #5 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
hello! you must be using Spiderman is interface? | |
6230i cant flash after mcu flash Write Error ?? | AnToS | Twisterflasher | 16 | 07-13-2005 20:22 |
6610 flash write error | baraka42 | Twisterflasher | 4 | 04-12-2005 12:44 |
Maxon 7922 Flash Write Error at 101000 ??? While Flashing UNLOCKED Flash File | Aamir_Zia | Redbox | 8 | 12-09-2004 19:11 |
3310 flash writing error | Moosani | Nokia Hardware & Hardware Repair | 0 | 09-02-2003 10:55 |
