Old 06-18-2008, 14:24   #1 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 994
China Mobiles Keypad Solution
Many times i have got China mobiles with keypad problems, Actualy i want to know that what is the problem, is it software problem or hardware, how can i guess. Please explain me all.
Old 06-18-2008, 14:30   #2 (permalink)
Member: 333417
Sonork: zakariya
Keypad Problem
Originally Posted by alamgarh View Post
many Times I Have Got China Mobiles With Keypad Problems, Actualy I Want To Know That What Is The Problem, Is It Software Problem Or Hardware, How Can I Guess. Please Explain Me All.
No Chinses Handset May Be Keypad Problem In Software. It Always Hardware Compliaint.what's The Real Problem Of U R Handset
Old 06-18-2008, 17:51   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
we have met very few models which after complete format displayed pushed buttons uncorrectly.
for example you press "5" it shows "2"
all other problems are hardware faults
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post:
Old 06-27-2008, 17:59   #4 (permalink)
Member: 26623
Thanks Meter: 88
i have problem when you click "1" phone show 6 , "2" is 4, "3" is 5, "4" is 9 i think that is software problem , how i can solve this
Old 06-27-2008, 18:40   #5 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
I suggest you to check hardware first.
If you are sure that it's software problem you can try to flash phone with different flash files from Infinity-Box support area
Old 06-27-2008, 18:44   #6 (permalink)
Member: 26623
Thanks Meter: 88
problem is software, but i flash whit many flashes and only one can power phone and then is keypad wrong, can you edit in flash Keypad map?
or any soft can edit flash whit this function
Old 06-27-2008, 20:50   #7 (permalink)
Member: 130995
if you think that it's software problem you have only one method: you must find exactly the same phone and use backup from that phone to repair damaged phone
Old 06-27-2008, 21:56   #8 (permalink)
Member: 26623
Thanks Meter: 88
software is 100% because phone was restarting and somebody is flash this phone on Spiderman with wrong flash and kill phone
Old 08-26-2008, 15:06   #9 (permalink)
rekha1255's Avatar
Member: 333796
Sonork: 100.1587155
Thanks Meter: 83
i hAVE A CHINA MTK CPU SCREEN TOUCH IS WORKING FINE & ALL KEY IS NOT WOKRKING ANY SLOUTION PLESE HELP ME !!!
Old 08-26-2008, 20:52   #10 (permalink)
cdma-india's Avatar
Member: 98139
Thanks Meter: 126
maximum keypad problem can be solved by replacing touch screen , ihave tested in many sets
The Following User Says Thank You to cdma-india For This Useful Post:
Old 09-15-2008, 19:35   #11 (permalink)
astana2007's Avatar
Member: 285345
Thanks Meter: 324
I also have a set with same problem.
touch screen is working fine,while during using its keypad it doesnt working properly.
press 1 show 3.
press 2 show 7.
press menu show something else.
all keys r working but with wrong order
Old 09-15-2008, 23:03   #12 (permalink)
Member: 148515
hello mr. astana2007!
Did you get this phone in such condition ?
or this is a result of some software operation?
Old 09-20-2008, 19:20   #13 (permalink)
Member: 659542
Thanks Meter: 3
mychina a5 55555555555keylong working only heip me
Old 09-21-2008, 14:20   #14 (permalink)
Member: 130995
Hello,
Open phone and clean water.
Also check phone keyboard, it looks like it's damaged.
Old 01-24-2010, 20:30   #15 (permalink)
Member: 432745
Thanks Meter: 10
China nckia n79 keypad not working after power phone please any solution
All China Mobile Pinout Solution cgsm Chinese Models & Cloned Phones 18 10-16-2010 09:28
china mobile sim solution, mobile tools and imei change tools Athie_dede Chinese Models & Cloned Phones 0 03-22-2010 01:44
china mobile imei solution vikas0734 Chinese Models & Cloned Phones 3 03-13-2010 15:18
China Mobiles Hardware Solutions Albert-M Chinese Models & Cloned Phones 0 05-21-2009 10:15
Page generated in 0.23827 seconds with 9 queries
