Old 09-25-2007, 18:01   #1 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 549
china model N91i dead
hi
China mercal n91i is dead itself (not fallen down) it takes amps with p/s
so i am sure its s/w problem . i need to know in witch way i may repair this phone with infinity (i am new user of infinity so need ur guidelines ) please guide me with steps .
i have charger connector of this model so need pin outs and the way of making cable
Old 09-25-2007, 18:53   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,290
1. you must read FAQ here: http:///vbb/forumdisplay.php?f=296
2. you must read information from C:\Program Files\InfinityBox\Documentation folder
3. you must make "search" in this forum
of course, you must be NOT LAZY before you will start to make steps 1-3
After you have some free time after steps 1-3 you must read this:
Due to a lot of different models with the same name but absolutely different hardware,
bottom connectors and different pinouts we recommend you to make detailed description of model,
attach phone photo, phone bottom connector photo and information about Gnd and Charge pins on phone bottom connector.
After you have this information prepared, please, check the next detailed description how to get pinout for your model:
use "Cable Selector": "Cable selector" at your service...
if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle.txt
if not helps, please read: http:///vbb/showpo...36&postcount=7
if not helps, please read: http:///vbb/showthread.php?t=433447
"ChineseMiracle": how to repair "reboot with SIM card"
1. make full flash backup for emergency case (use 921000 speed for fast operation)
2. select "safe format method"
3. make "format ffs"
4. remove/install battery
5. press and hold phone "Power" button during 30-40 sec to make phone powered-on
if phone Ok go to step-6
if phone not Ok, go to step 2 and select "complete format method"
6. restore original imei
7. if phone has touchscreen LCD make calibration: click to LCD corners one by one
if still no luck: check phone hardware
Old 09-26-2007, 13:48   #3 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 549
here is pictures please check
Old 09-26-2007, 22:20   #4 (permalink)
Ramzan's Avatar
Member: 86597
Sonork: 100.1602630
Thanks Meter: 1,122
Its 12 pin conector of N91i phone
key bord top
11 Tx
10 Rx
5 Gnd
enjoy it and post result
Its 100% tested by me
CELL-ZONE
MULTAN PAKISTAN
Old 09-27-2007, 10:08   #5 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 549
thanks sir will you more explane about making cable
will i use charger conecter of this modle ...please guide me if you have photos then please upload here
Old 09-27-2007, 14:52   #6 (permalink)
Ramzan's Avatar
Member: 86597
Sonork: 100.1602630
Thanks Meter: 1,122
N 91i Pinouts
Sorry its not 12 pin conector , Its 10 pin conector
I hope this will help u to made a cable
Old 09-27-2007, 14:52   #7 (permalink)
Ramzan's Avatar
Member: 86597
Sonork: 100.1602630
Thanks Meter: 1,122
N 91i Pinouts
Old 10-17-2007, 14:49   #8 (permalink)
IBMOBILES's Avatar
Member: 56157
Sonork: 100.1573682
Thanks Meter: 171
as i remmber it as fallowing
pinout
4: Rx
5: Tx
6: Gnd
hope it will work with you
Old 10-17-2007, 16:12   #9 (permalink)
Member: 129486
Thanks Meter: 66
Hello Ramzan can you give me flash file for Chinese N91i ?
china cesim model v30 dead sanjay telecom Chinese Models & Cloned Phones 1 02-17-2009 16:15
china ztc dule sim zt988 model is dead complete ffs mass_zoro Chinese Models & Cloned Phones 1 01-10-2009 13:29
china model N91i dead zeerik Infinity-Box 2 09-26-2007 13:35
required china model flash cdma-india Infinity-Box 1 07-05-2007 00:35
Page generated in 0.37716 seconds with 9 queries
