Old 01-06-2007, 10:10   #1 (permalink)
.::Zafar Communication::.'s Avatar
Member: 71045
Thanks Meter: 19
china n91 pinout need urgently
hi
need urgently nokia 91 china
thanks and regards
Zafar Janjua
Old 01-06-2007, 10:39   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
http://forum.gsmhosting.com/vbb/show...&postcount=180
What to do if you have "Made in China" phone but you don't have pinout:
1. what is full phone name
2. what is full text from phone back label
3. what is phone bottom connector type ?
4. attach phone connector photo (if possible)
5. go to support area, download existing pinouts and try to use pinouts from support area that looks suitable for you phone connector
6. if no luck: open phone, probably you will see test points with "Rx", "Tx", "Gnd" marks
7. if no luck: find on phone bottom connector all "Gnd" pins, all "+ battary" pins and all "charge" pins and give me this info ([email protected]), we will try to find pinout.
Old 01-06-2007, 10:47   #3 (permalink)
Member: 71045
Thanks Meter: 19
Originally Posted by InfinitySupport View Post
Hello,
Nokia
model N91
type:RH-64
IC:661U-RH19
i have usb cable plus charger
8pin mini connector
thanks for immidiate reply
thanks & regards
Zafar Janjua
Old 01-06-2007, 17:51   #4 (permalink)
Member: 130995
Hi,
cool info about phone. It looks like you did not read my previous message carefully.
where is 4 USB wires located (+V, Usb-, Usb+, Gnd) on phone connector ?
also, if phone has 8 pin mini-usb connector: check support area to see standard pinout for 8-pin miniusb connector
Old 01-07-2007, 06:22   #5 (permalink)
halongmobile's Avatar
Member: 45580
Thanks Meter: 48
1: Gnd
2: Tx
3: Rx
Old 10-02-2007, 13:38   #6 (permalink)
Member: 202611
Thanks Meter: 51
Originally Posted by halongmobile View Post
1: Gnd
2: Tx
3: Rx
yes it tested with me and works perphect thanx
Old 12-06-2007, 22:56   #7 (permalink)
Member: 158471
Sonork: 100.1588029
Thanks Meter: 120
connector_2x6_mini.
any help
Old 12-07-2007, 00:24   #8 (permalink)
Member: 148515
Thanks Meter: 19,534
hello el-safwa!
what help you need with connector 2x6?
Old 12-07-2007, 17:30   #9 (permalink)
Member: 158471
Sonork: 100.1588029
Thanks Meter: 120
hi sir yes my phone n91
.................................................. .....my connector_2x6_mini .............................
and I understand tihis post
Due to a lot of different models with the same name but absolutely different hardware (f.e. exist at least 5 phones with name "Chinese Nokia-N95" but different pinouts),
bottom connectors and different pinouts we recommend you to include the next info:
1. detailed description of model
2. phone CPU chip name
3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB)
4. attach phone photo
5. attach phone bottom connector photo
6. include information about Gnd and Charge pins on phone bottom connector
After you have this information prepared, check the next detailed description how to get pinout for your model:
use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297
if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\
if not helps, please read: http:///vbb/showpo...36&postcount=7
if not helps, please read: http:///vbb/showthread.php?t=433447
Old 12-07-2007, 20:46   #10 (permalink)
Member: 130995
@el-safwa
Very good that youmhave read and understand. Now it's time to follow all steps that was given in my instruction.
Old 12-07-2007, 21:09   #11 (permalink)
Member: 630874
Originally Posted by .::Zafar Communication::. View Post
hi
thanks and regards
Zafar Janjua
Just open the phone and remove the black sticker from the circuit u will get the rx,tx,gnd printed on the board.
B,r.
Old 08-26-2008, 10:57   #12 (permalink)
MGT SOFTWARE's Avatar
Member: 53263
Sonork: gsm master
Thanks Meter: 326
can you post or upload circuit diagram for n91
Old 07-26-2011, 18:35   #13 (permalink)
Member: 516860
Sonork: chickiesmp
Thanks Meter: 12
mine is itel it200.
i need tx,rx points
9300 Pinouts Need Urgently .. Aamir_Zia UFS2 + UFS3-Tornadoflasher 7 01-20-2011 08:50
n96 nokia china phone pinout needed.. .:UnitedGSM:. Infinity-Box 7 06-21-2009 07:24
china N73 pinout need mobile maker Infinity-Box 1 03-18-2008 17:24
china N73 pinout need mobile maker Chinese Models & Cloned Phones 11 03-17-2008 09:05
China Model Pinouts Needed jbbasha Infinity-Box 14 10-25-2007 16:59
Page generated in 0.22407 seconds with 9 queries
