03-20-2008, 13:22 | #1 (permalink) |
Temporary banned !! Join Date: Jul 2007 Location: Toketek Age: 44
Member: 546766 Status: Offline Thanks Meter: 51 | china n92 dual sim phone dead after format now which file select for flash......... same file have or no in infinity support area.pls suggest. here is log. COM6 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 chip: 0031:6AF5:84A8 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb Warning: probably flash chip empty, erased, incorrectly flashed or damaged. What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_***x_***x.bin detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: EC257E25082501:FFFFFF00000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF reading [eeprom]... file saved: C:\Documents and Settings\Administrator\Desktop\backup_eeprom_20080 320-181858.B0E.bin flash: EC257E25082501:FFFFFF00000000 Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... formatting... flash: EC257E25082501:FFFFFF00000000 Write Done Finished, time used: 326 sec Remove/Install battery now ! |
03-22-2008, 18:04 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | As per your log I can see that flash chip in your phone is completely erased. It's not true that phone dead after format, you must explain what you have tried to do with phone step-by step ! |
03-23-2008, 05:46 | #5 (permalink) |
Member: 546766 Status: Offline Thanks Meter: 51 | thanks for your understanding. first i am format my set with mtk .after format i see set is blicking only white screen.then i try to format with infinity,.after format with infinity set is totaly dead.after dead i am try to many other option.like complete format ffs format and other . but my phone is stil dead. |
03-23-2008, 13:53 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i think that MTK erased flash. because of that it is impossible to advice file, becuase we dont know original phone version. the only way for you is to find similar phone on your local market and try to use it's backup to restore dead phone. or post your phone photo, maybe some forum member will tell you which version it could be |
chaina phone dead after format by using infinity Box | MANfaith | Chinese Models & Cloned Phones | 9 | 09-06-2009 08:38 |
china n92 dual sim @tested@ flash file.... | /ARIF/ | Infinity-Box | 12 | 02-16-2009 06:09 |
bluetooth china phone dead after formating | Gordak_air | Chinese Models & Cloned Phones | 2 | 11-27-2008 08:19 |
n95 dual sim display problem after format..... | unlock & flash | Infinity-Box | 11 | 04-28-2008 09:59 |
china n92 dualsim phone dead after format with infinity | /ARIF/ | Chinese Models & Cloned Phones | 1 | 03-22-2008 01:24 |
