China Nokia 2310 Bad Software Infinty Team: Kindly Help me i have China Nokia Model:2310 in fault of Bad-Software and i repair it from chinees miracal sftware but it cannot ok after processe some error i fce in this sofware i send you it opration log kindly note it and give any solution. Log: COM3 [VCP0] selected module v3.07 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: repair "Bad software" mode: mode-1 ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A04:8A00]... CPU: MT6223 high speed boot On chip: 0011:954F:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #04 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #05 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #06 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #07 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 08/01 Initialize Done ====> Set baud ... 230400 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.07, database date: 24.01.2010): SG2323_NO_CN_PCB01_GPRS_MT6223P_S00.SG2323_NO_CN.B IN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 04 sw version: SG2323_NO_CN_PCB01_GPRS_MT6223P_S00.SG2323_NO_CN.B IN project-id: SG2323_NO_CN, 00000000 code offset: 00000000 ffs offset/size [01]: 00700000/00100000 rom info structure: 2nd [standard] generation TCL-ID is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... detecting licence parameter... detecting licence parameter name... phase #1... ................................ phase #2... ...................... done detecting licence parameter value... detecting area #1... ................................ detecting area #2... ................................ detecting area #3... ................................ done error: licence parameter value is not found or incorrect What to do: 1. Be sure that your phone really has "Bad software" problem, in other case do NOT use "Bad software" button ! 2. Repeat "Bad software" operation several times to avoid communication problems. 3. Flash phone with firmware from support area and repeat "Bad software" operation. If still no luck: 1. read full flash and send to support: [email protected] 2. send "operation.log" file to support: [email protected] Finished, time used: 2 min 30 sec Remove/Install battery now ! Thanks |
hello! please follow advice and send full flash file to [email protected] make subject "BAD SOFTWARE" |
hello plaese aim need full flah nokia 1110i in prplam bad saftware . |
what is your phone software version? |
it is firmware version in this phone SG2323_NO_CN_PCB01_GPRS_MT6223P_S00.SG2323_NO_CN__ fullflash_20100214-202125.B0M |
i got your file in Email. we will check what is wrong with this firmware |
