10-04-2007, 19:09 | #17 (permalink) |
No Life Poster Join Date: Sep 2005 Location: INDONESIA Age: 38
Member: 183921 Status: Offline Sonork: 100.1590817 Thanks Meter: 205 | this one sir... look same as ur phone, but in behind write "NOKIA Q7+" this phone also have printed RX TX in board, but cant connect using that.. br, kevin168 |
10-06-2007, 22:26 | #20 (permalink) |
Member: 183921 Status: Offline Sonork: 100.1590817 Thanks Meter: 205 | i think both cable was same... hehehehe.......... i can't conect until now.. @infinity support can u give me the one workin pin out?? br, kevin168 |
10-06-2007, 22:43 | #21 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @kevin168 Due to a lot of different models with the same name but absolutely different hardware, bottom connectors and different pinouts we recommend you to make detailed description of model, attach phone photo, phone bottom connector photo and information about Gnd and Charge pins on phone bottom connector. After you have this information prepared, please, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle.txt if not helps, please read: http:///vbb/showpo...36&postcount=7 if not helps, please read: http:///vbb/showthread.php?t=433447 |
10-07-2007, 17:37 | #24 (permalink) | |
You are the most hardworking man about this phone model that I ever have seen. My respect and congratulations ! Could you, please, explain all your steps in your really hard work so other people can see all your steps and get new experience. Also this your description may helps to other people to understand what kind of problem you have (it's impotrtant, because you tried everytrhing but pinout still not found and phone still not connected). It looks like you have in hands very new phone with very new pinout so all you detailed step-by step description is very welcome. | |
10-08-2007, 16:33 | #25 (permalink) | |
Member: 183921 Status: Offline Sonork: 100.1590817 Thanks Meter: 205 | Quote:
coz i have so much to do in this several days.. br, kevin168 | |
10-14-2007, 11:00 | #26 (permalink) |
Member: 183921 Status: Offline Sonork: 100.1590817 Thanks Meter: 205 | COM20 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: write NOR flash "smart write" active write: Firmware skip: Customization skip: Language Pack skip: Eeprom Boot... Press and HOLD Power button now ! baud autodetection active 9600 Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 3 sec Remove/Install battery now ! sometimes i get response like this... but ussually wont detect anything.. wait a minute i'll post the picture phone.. br, kevin168 |
10-14-2007, 11:17 | #27 (permalink) |
Member: 183921 Status: Offline Sonork: 100.1590817 Thanks Meter: 205 | COM20 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read eeprom Boot... Press and HOLD Power button now ! baud autodetection active 9600 Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 3 sec Remove/Install battery now ! sometimes like this, but still cant connect to phone.. what should i do?? br, kevin168 |
10-14-2007, 13:09 | #29 (permalink) |
Member: 183921 Status: Offline Sonork: 100.1590817 Thanks Meter: 205 | im sorry i made a big mistake to match TX RX in box, ur pin was workin OK now, sorry for my mistake make everybody confuse.. br, kevin168 |
01-05-2011, 07:52 | #30 (permalink) | ||
No Life Poster Join Date: Mar 2008 Location: VIZAG,A.P,๑۩INDIA&
Member: 733702 Status: Offline Sonork: 100.1579452 Thanks Meter: 580 | Quote:
Quote: i need nokia Q7 flash file anyone upload for me plss thanks. | ||
china nokia 6300D flash file req. pcb ver:6300-v3.1 2009/05/19 | nakshatra | Chinese Models & Cloned Phones | 2 | 05-29-2010 06:06 |
china nokia 6300D flash file req. | nakshatra | Chinese Models & Cloned Phones | 2 | 01-06-2010 04:17 |
CHINA NOKIA 5610i FLASH FILE NEEDED | technicservice | SpiderMan | 1 | 08-21-2009 12:11 |
nokia Q7+ flash file | biddut1979 | Chinese Models & Cloned Phones | 0 | 06-05-2008 12:39 |
china 6300 Q7+ flash file needed. | coolshahul | Infinity-Box | 10 | 03-14-2008 21:08 |
