11-23-2009, 10:47 | #1 (permalink) |
No Life Poster Join Date: Aug 2009 Location: faisalabad PAKISTAN
Member: 1092450 Status: Offline Thanks Meter: 196 | china phone is dead plz helpme Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:4403:0003 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:00E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:00E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #02 in region #00... flash: 98004900000002:00E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #03 in region #00... flash: 98004900000002:00E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98004900000002:00E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:00E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 00009FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: PROWAVE25_GEMINI_PCB01_GPRS_MT6225_S00.LT526B_R1_0 _39_3.BIN ver. sw 2: LT526B_R1.0.39.3, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98004900000002:00E59F00000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: PROWAVE25_GEMINI_PCB01_GPRS_MT6225_S00.LT526B_R1_0 _39_3__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\PROWAVE25_GEMINI_ PCB01_GPRS_MT6225_S00.LT526B_R1_0_39_3__ffs_200911 23-014057.B0E.bin flash: 98004900000002:00E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 98004900000002:00E59F00000000 Finalization Done Finished, time used: 317 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
11-23-2009, 19:43 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! do following: go to flashing Tab, load as EEPROM this file: C:\Program Files\InfinityBox\ChineseMiracle\PROWAVE25_GEMINI_ PCB01_GPRS_MT6225_S00.LT526B_R1_0_39_3__ffs_200911 23-014057.B0E.bin write it back to phone. it should be back to life and next try safe format. FOr sure it is very smart idea always use latest available EXE |
3110c flash log phone is dead how to sovel this problem plz | junaid_shaikh | Nokia Hardware & Hardware Repair | 5 | 03-24-2010 12:43 |
kg 195 after formet wole flash phone is dead plz help me | mobiletuch | LG Hardware Repair | 2 | 02-16-2010 17:16 |
plz help me phone is dead | amralkareem | Infinity-Box | 3 | 11-30-2009 21:47 |
°°°°((( Plz help, my Smart clip is Dead Plz help )))°°° | xsat2004 | Smart-Clip | 3 | 09-20-2007 13:52 |
