Old 02-06-2008, 08:51   #1 (permalink)
alfox's Avatar
Member: 91411
Sonork: 100.1584444
Thanks Meter: 372
china phone N6128 autoshut off w/sim[reference]
heres another common scenario for china phones.auto shut off when inserted with sim....
Heres the pinout:
Heres the actual Phone:
back up process:
COM4 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: read NOR flash
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
chip: 0031304:0069
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
921600
Set baud Done
Identification...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.BFACEFF6.[E558_ND2_E558_GPRS_MT6226_S01.01_1.BIN_722D94F9].rpl
New firmware detected:
- make "Repair security area" operation
- send "backup_system_log_..." file to support
- make "Read full flash" operation
- send flash backup file(s) to support
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: BFACEFF6
identification#1 protocol ver: 04
ver. sw1: E558_ND2_E558_GPRS_MT6226_S01.01_1.BIN
ver. sw2: E558_ND2.01.1, 066BD28D
ffs offset/size: 00800000/001FF000
detect device identification#2...
warning: optional information not found
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00800000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
Detected eeprom/ffs address is non-standard: 00E00000
Posible reasons:
1. eeprom is Ok but address is non-standard
2. eeprom damaged and can't be detected
3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make flash backup for emergency case
3. repeat required operation
Are you sure that detected eeprom address is correct ?
autodetected eeprom/ffs address[00E00000] confirmed by user
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
reading [flash[E558_ND2_E558_GPRS_MT6226_S01.01_1.BIN]]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_flash[E558_ND2_E558_GPRS_MT6226_S01.01_1.BIN]_N6128autoOff20080206-145953.B0M.bin
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _BFACEFF6_E558_ND2_E558_GPRS_MT6226_S01.01_1.BIN_7 22D94F9_20080206-150019.B0X.bin
Finished, time used: 656 sec
Remove/Install battery now !
Format Process:
Action: reset settings
Model: Autodetect 6205-6227 NOR
19200
CPU: MT6226
chip: 0031304:0069
Connecting, wait...
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: E558_ND2.01.1_26S01
Version: M500Z_05C_HW
detecting structure #2...
done
60 byte(s) read
imei: 35456500271691
connection Ok
building list...
done
items to clear: 210
warning: wrong packet cs
208 of 210 items cleared
building list...
done
2 items remains
Finished, time used: 47 sec
Restore imei:
Action: imei
Phone should be Switched ON !
Connecting, wait...
Hardware version: MT6226, E02
Hardware version: M500Z_05C_HW
Software version: E558_ND2.01.1_26S01"
Software date: 2005.04.12
Barcode: MT012345678901234567
imei: 135790246811220
imei write method: mode-1
new imei: 354565002716912
imei verified Ok
Finished, time used: 30 sec
Power off phone now !
Old 02-06-2008, 10:17   #2 (permalink)
tsarkh's Avatar
Member: 165812
Sonork: 100:1627635
Thanks Meter: 4,267
good job and thank u for PINOUTS OF THIS MODEL
KEEP IT UP
Old 02-06-2008, 19:01   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
thank you for sharing this!!!
Old 02-07-2008, 04:09   #4 (permalink)
alfox's Avatar
Member: 91411
Sonork: 100.1584444
Thanks Meter: 372
its an honor to share here for the benefit of us all.thanks infinityhelp for supporting us end users....
need flash file n6128 china phone "frankiSta" Chinese Cocktail 1 07-02-2008 11:26
does anyone have pinout for N6128 bluetooth china phone? alfox Infinity-Box 10 07-02-2008 07:44
6300 china phone, auto shut off fixed by infinity rea1One Infinity-Box 3 02-15-2008 08:49
6300 china phone auto shut off w/sim fixed[reference] alfox Infinity-Box 5 02-13-2008 05:25
6300 china phone auto shut off w/sim fixed[reference] alfox Infinity-Box 1 02-07-2008 08:25
Page generated in 0.21690 seconds with 9 queries
