01-17-2018, 22:23 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: BEST COUNTRY
Member: 421947 Status: Offline Sonork: 100:1658491 Thanks Meter: 239 | china sanlong s77 fw pb Card found : S/N : 48F9D065 , v0136 Chinese Miracle II [MTK module] v 1.58 User selected DumpFile , extracted : preloader_hys72kk_c300_s6_1_2g.bi Operation : Init Preloader [ v1.58 ] Supported HW by Preloader : FlashID [0] CID : 0000000005000000C8 , Name : FlashID [1] CID : 0000000005000000C8 , Name : FlashID [2] CID : 0000000005000000C8 , Name : FlashID [3] CID : 0000000004000000C8 , Name : FlashID [4] CID : 0000000005000000C8 , Name : FlashID [5] CID : 0000000005000000C8 , Name : FlashID [6] CID : 0000000004000000C8 , Name : FlashID [7] CID : 0000000005000000C8 , Name : 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8C00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : 002C00BC009000550056000000000000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0091 , [Micron] NAND_MT29C4G48MAAHBAAKS_5WT [NAND] : FLASH_DIE : 002C 00BC 0090 0055 0056 0000 0000 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/00/NIM_Px-2 DEV RID : 0x30AFE4776CFAC4EB49061B24735776E5 INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SecCfg Passed , 1799 BL : BBID supported by BootLoader! Supported HW by Preloader : FlashID [0] CID : 0000000005000000C8 , Name : FlashID [1] CID : 0000000005000000C8 , Name : FlashID [2] CID : 0000000005000000C8 , Name : FlashID [3] CID : 0000000004000000C8 , Name : FlashID [4] CID : 0000000005000000C8 , Name : FlashID [5] CID : 0000000005000000C8 , Name : FlashID [6] CID : 0000000004000000C8 , Name : FlashID [7] CID : 0000000005000000C8 , Name : STORAGE : BL NOT support this eMMC! Select Correct One! Done! Elapsed: 00:00:18 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Open port error , something went wrong! Boot Error! Operation Failed Elapsed: 00:00:00 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8C00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : 002C00BC009000550056000000000000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0091 , [Micron] NAND_MT29C4G48MAAHBAAKS_5WT [NAND] : FLASH_DIE : 002C 00BC 0090 0055 0056 0000 0000 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/00/NIM_Px-2 DEV RID : 0x30AFE4776CFAC4EB49061B24735776E5 INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Error read initial info! Make "Identify" first! Operation Failed Elapsed: 00:00:11 Reconnect Power/Cable! Load File Bad file detected! Load File Bad file detected! Thare is china Sanlong s77 That have sw pb and I have download file MT6572__hys72kk_c300_s6_1_2g.ispff but cant flash it Thanks a lote |
