Old 10-07-2009, 12:49   #1 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
CHINA set BLOCK in PAKISTAN again
infinity user congratulation
china set block again
13************ blooooooooocked
i had repair 6 set today
The Following User Says Thank You to cel_phon For This Useful Post:
Old 10-07-2009, 12:53   #2 (permalink)
shahzaadbutt's Avatar
Member: 123458
Sonork: 100.1594535
Thanks Meter: 3,421
yes after format IMEI change to 13xxxxxxxxxxxxx, just rebuild imei to its original all will be ok
Old 10-07-2009, 13:28   #3 (permalink)
tom313rd's Avatar
Member: 436045
Sonork: 1581208
Thanks Meter: 31
Wow!!! but is it really true???
I fixed one Dual imei fone though but not sure if the issue again popped up!!! anyways if it is so then its easy money hehe
Regards,
TOm
Old 10-07-2009, 17:56   #4 (permalink)
astana2007's Avatar
Member: 285345
Thanks Meter: 324
I have 4 different pieces of chinies set.
but I m unable to change 2nd IMEI.
also select 2nd mode and select IMEI 2 for dual sim cpu.
but all teme imei will same 135790246811220.
anyone have working solution????????
Old 10-07-2009, 18:10   #5 (permalink)
Member: 130995
Thanks Meter: 35,227
Please, post here operation log so we will be able to check what is wrong.
Old 10-07-2009, 18:24   #6 (permalink)
astana2007's Avatar
Member: 285345
Thanks Meter: 324
COM3 [VCP0] selected
module v2.93
Action: imei
imei write method: mode-2
imei write channel: imei #2 for dual sim/mono CPU
new imei: 350566577234566
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:6B03:000C
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6225,E03
Date: 2006.06.14
Version: 1.0
Version: MT6225_GEMINI_V1.00
Version: MT6225_GEMINI_HW
detecting structure #2...
5 11 done
67 byte(s) read
imei: 35056655423456
connection Ok
5 11 done
67 byte(s) read
verification...
verification done: 35056657723456
Finished, time used: 11 sec
Remove/Install battery now !
also format it but still same
also check to change pc
Old 10-07-2009, 18:58   #7 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
Same Problem Discussion,
https://forum.gsmhosting.com/vbb/f36/phone-imei-135790246811220-blocked-pakistan-837525/
The Following User Says Thank You to Shakeel_pattoki For This Useful Post:
Old 10-07-2009, 21:11   #8 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
try to use mode-1 for second IMEI change. what result?
Old 10-08-2009, 07:52   #9 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
imei pepair LOG`s by INFINITY Box
==== log: [10/7/2009 10:59:49 PM] ====
COM24 [VCP1] selected
module v2.75
Action: imei
imei write channel: imei #1 for dual sim/mono CPU
new imei: 355790246811225
19200 autodetect
Initializing [6223:8A04:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:2A3E:000C
Connecting, wait...
Hardware: MT6223,E04
Date: 2000.00.00
Version: 1.0
Version: MAUI.07A.W07.36.MP_1.V4
Version: PHONE23_07A_HW
0 done
44 byte(s) read
imei: 13579024681122
warning: current phone imei is incorrect !
It's need to repair imei for correct phone functionality !
connection Ok
0 done
44 byte(s) read
verification...
verification done: 35579024681122
Finished, time used: 13 sec
==== log opened: [10/7/2009 10:50:56 PM] ====
Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e
Loading data, wait...
[Infinity Box] v2.75
S/N: 5E49:0112
Wait...
Device: Autodetect 6205-6227 NOR
Done
Imei 35579024681122 already was repaired: 10/7/2009-10:10:21 PM
Continue with this imei ?
Action: imei
Phone should be Switched ON !
Connecting, wait...
Hardware version: MT6225, E03
Hardware version: Telsda25_06B_HW
Software version: TP023_25_MT6225_1.0.
Software date: 2006.06.14
Barcode: MT012345678901234567
imei: 135790246811220
imei write method: mode-1
verification Ok
Finished, time used: 5 sec
Power off phone now !
==== log: [10/7/2009 10:10:04 PM] ====
module v2.75
Action: imei
19200 autodetect
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:3FAC:A5BE
Connecting, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: RDR26_05C_NOKIDE800B_GB_V02.10_071210
Version: MIKI26_05C_HW
done
60 byte(s) read
connection Ok
done
60 byte(s) read
verification...
Action: read information
Connecting, wait...
Hardware version: MT6226, E02
Hardware version: MIKI26_05C_HW
Software version: RDR26_05C_NOKIDE800B
Software date: 2005.04.12
Finished, time used: 6 sec
==== log opened: [10/7/2009 4:27:37 AM] ====
S/N: 5E49:0112
Wait...
Done
Action: imei
Connecting, wait...
baud set to: 9600
error: connection failed !
operation failed !
Finished, time used: 12 sec
Imei 44912788876403 already was repaired: 10/7/2009-4:31:17 AM
Action: imei
Connecting, wait...
baud set to: 19200
operation failed !
Finished, time used: 79 sec
Imei 44912788876403 already was repaired: 10/7/2009-4:32:59 AM
Action: imei
Connecting, wait...
baud set to: 19200
operation failed !
COM24 ready
Imei 44912788876403 already was repaired: 10/7/2009-4:34:40 AM
Action: imei
Connecting, wait...
Hardware version: MT6225, E05
Hardware version: G60V1.0
Software version: V04.20"
new imei: 449127888764032
verification Ok
Finished, time used: 57 sec
Connecting, wait...
Imei 44912788876403 already was repaired: 10/7/2009-4:35:56 AM
==== log: [10/7/2009 4:37:16 AM] ====
COM24 [VCP2] selected
module v2.75
Action: imei
19200 autodetect
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:F003:0003
Connecting, wait...
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: V04.20
Version: G60V1.0
5 11 done
67 byte(s) read
connection Ok
5 11 done
67 byte(s) read
verification...
verification done: 44912788876403
Finished, time used: 24 sec
Connecting, wait...
Action: imei
Connecting, wait...
new imei: 359127888764030
verification Ok
Connecting, wait...
Imei 35912788876403 already was repaired: 10/7/2009-4:39:06 AM
Action: imei
Connecting, wait...
verification Ok
Connecting, wait...
Old 10-08-2009, 08:13   #10 (permalink)
HAROON's's Avatar
Member: 100592
Sonork: 1578498
Thanks Meter: 245
imei is unblocked fom PTA done
check for conformation ... pta.gov.pk
regards
Haroon
Old 10-08-2009, 08:15   #11 (permalink)
intelp3's Avatar
Member: 398035
Thanks Meter: 51
try to mode3 and select 2nd imei dual sim for mono cpu. post result.
<<< Phone IMEI :135790246811220 Blocked In Pakistan >>> Shakeel_pattoki Off Topic Zone 20 10-09-2009 08:25
China Mobiles Blocks in Pakistan. masterunlock Off Topic Zone 2 02-28-2009 16:57
PAkistan Telecom Block CHina Mobiles in Pakistan. mohsin10 Infinity-Box 39 01-24-2009 13:03
china phones block in india 10t ovmber tru our not help me nasermmx Infinity-Box 6 10-27-2008 13:24
Page generated in 0.25339 seconds with 9 queries
