Old 01-14-2009, 13:10   #1 (permalink)
Member: 471808
Thanks Meter: 5
china set dead
I HAVE CHINA SET..MENU WAS NOT OPENING AFTER INSERTING SIM....SO I FORMATTED IT WITH INFI ....BUT NOW SET IS DEAD. OPERATION LOG IS ATTATCHED....CFI 0098 0049 0000 0002.bin
COM17 [VCP0] selected
module v2.74
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: "format ffs"
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:A503:000C
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 98004900000002:FFFFFF00000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud ...
230400
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
Warning: probably flash chip empty, erased, incorrectly flashed or damaged.
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box UN-CHECKED !
3. make flash write operation
If still no luck: send mail to support ([email protected]) with detailed description of problem,
attach the next files in your e-mail:
1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log
2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin
it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
detect device identification#2 finished
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset assigned: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: eeprom...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom_20090114-182437.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
Finished, time used: 252 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
error: wrong file size[0x00000200]: C:\Program Files\InfinityBox\ChineseMiracle\cfi_0098_0049_000 0_0002.bin
Old 01-17-2009, 16:51   #2 (permalink)
Member: 148515
Thanks Meter: 16,255
hello!
this is a log of format FFS on phone with totally erased flash chip
open operation.log and find First operation which you did with this phone.
check its original firmware version and find proper flash file on our support area
Help infinity team china set dead after full format? malikawan Infinity-Box 3 10-02-2009 10:38
china set dead by format with infinity eswar7983 Infinity-Box 6 06-03-2009 23:01
N95 8gb china phone dead set pls help topnoyze PadFinder box 1 08-12-2008 07:52
after format my china set full dead unlock & flash Chinese Models & Cloned Phones 13 05-25-2008 14:16
plz help dead china set asad_nomy7 Infinity-Box 7 03-28-2008 11:50
Page generated in 0.26561 seconds with 8 queries
