09-04-2015, 14:56 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | inetx aqua 3G+ patern code perfect Code: Chinese Miracle II [SPD module] v 1.03 SLDR Load Ok BB CPU : SC7715 Aqua3G+ [eMMC 4GiB] [RAM 512MiB] For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab! Operation : Check/Read Info [ v1.03 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 95 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : w131_kew_111 Model Brand : Intex Model Device: w131_kew_111 AndrVersion : 4.4.2 BaseBand CPU: W131_KEW_111 CompileDate : 1428494978 Project Ver : MocorDroid test-keys Model Ext : Aqua_3G+ Elapsed: 00:00:14 Reconnect Power/Cable! Operation : Read PatternLock [ v1.03 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 73 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! Reading PatternLock ... Read Ok , decrypt PatternLock Sequence : 159873 Done! Elapsed: 00:00:10 Reconnect Power/Cable! |
