Old 07-31-2008, 05:36   #1 (permalink)
vlmobiles's Avatar
Member: 560942
Thanks Meter: 78
Chines iphone Q380 No power on
cect Q380-A
Am full flashed
Full Formated
Still no power on
Plz help me infinity team
Thanx&Regards
KOTESHWAR
Old 07-31-2008, 06:28   #2 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,052
Originally Posted by vlmobiles View Post
cect Q380-a
Am Full Flashed
Full Formated
Still No Power On
Plz Help Me Infinity Team
Thanx&regards
Koteshwar
Can You Flash Your Phone In Wright Flash File??? Post Your Ditels.
The Following User Says Thank You to debmobile For This Useful Post:
Old 07-31-2008, 06:40   #3 (permalink)
SMDSAFE's Avatar
Member: 311990
Thanks Meter: 146
yes please give me the deatails
Old 07-31-2008, 10:42   #4 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,052
Originally Posted by smdsafe View Post
yes Please Give Me The Deatails
Why You Tell Give Ditels? I Don't Face This Problem. Who Face The Problem I Am Tell Plese Post Ditels.
Old 08-23-2008, 11:47   #5 (permalink)
Registered User
Member: 388621
Thanks Meter: 10
COM4 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: "format ffs"
Boot...
19200 fixed
Connecting, wait...
Initializing[6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001:AA03:0001
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
460800
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: R:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.E644D0A6.[TOPWISE25_07A_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_3 2_MP_V7_M521.BIN_B5F5B34B].rpl
identification#1 detection finished
device-id: E644D0A6
identification#1 protocol ver: 04
ver. sw1: TOPWISE25_07A_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_3 2_MP_V7_M521.BIN
ver. sw2: MAUI.07A.W07.32.MP.V7_M521, B44C0A4A
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
Can't detect eeprom/ffs area
Do you want to use standard ffs address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
operation terminated by user
error: critical error#1 during ffs size detection
error: can't detect eeprom/ffs address/size
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
file saved: R:\Program Files\InfinityBox\ChineseMiracle\system_log_E644D0 A6_TOPWISE25_07A_PCB01_GPRS_MT6225_S00.MAUI_07A_W0 7_32_MP_V7_M521.BIN_B5F5B34B_20080823-161550.B0X.bin
Finished, time used: 61 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
but not Powered-On
Old 08-23-2008, 12:35   #6 (permalink)
kanapuza's Avatar
Member: 573543
Sonork: 100.1602019
Thanks Meter: 97
Boot...
19200 fixed
Connecting, wait...
CPU: MT6225
Boot Done
Initialize...
Initialize Done
Set baud...
460800
Set baud Done
device-id: E644D0A6
Write...
Write Done
Finalization...
formatting...
Finalization Done
but not Powered-On
hi.
pls give me the iphone pinout
thnx
Old 08-23-2008, 21:05   #7 (permalink)
Member: 148515
Thanks Meter: 19,534
hello celltronix_cbe!
flash your phone, if it doesnt power On
Old 09-25-2008, 21:01   #8 (permalink)
Member: 804308
Sonork: 0000000
i have same prob help please
Old 09-27-2008, 22:29   #9 (permalink)
Member: 148515
hello mr. piratekhan2!
if flashing with correct flash file do not help- try to make format FFS complete.
if still not luck- check hardware
Genie dead no power on... [ANSWERED] lchico Genie Universal 1 03-29-2010 07:18
7610 power on problem no power on with power touch shani72 Nokia Hardware & Hardware Repair 2 09-10-2008 05:51
x100 software is ok keypad light on but on batt no power on shani72 Samsung Hardware Repair 1 07-13-2008 18:42
6280 with JAF power on ,battery no power on ? NOKIA_TR Nokia Hardware & Hardware Repair 0 07-30-2007 11:53
3220 no power on, but the power button is good real1ed Nokia Hardware & Hardware Repair 8 03-20-2006 18:29
Page generated in 0.24097 seconds with 9 queries
