Old 03-29-2010, 12:28   #1 (permalink)
nadirghazi's Avatar
Member: 779665
Sonork: 100.1581784
Thanks Meter: 492
Chines model wont turn on
HI Infinity team i got chiness mtk 6225 cpu model its brand new i formate it flash with some difrent firmwares but could,nt power on sorry i dont have its orignall flash back up file if u help me i will apreciate it thanks
COM6 [VCP0] selected
module v3.08
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: write flash
"smart write" active
write: Firmware
MT6225_GEMINI_PCB01_GPRS_MT6225_S00.M6225_00J6_HTC 1_00_V04__Daxian-J6_16m_En_Cn.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:8403:0002
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC240200000000:18A59F00000000
flash: Samsung K5L2833ATA T 16Mb
otp offset: 00FF0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
warning: rom info information not found, possible reasons:
- old firmware type w/o rom info information
- empty (completely or partially erased) flash chip
- damaged firmware
- damaged hardware (bad soldered or damaged flash chip)
> if phone works fine just ignore this warning <
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset assigned: 00E00000
checking area [00000000]: 00080000-00FFFFFF...
ffs/eeprom found near: 00290000
Detected ffs/eeprom address is non-standard: 00290000
Posible reasons:
1. ffs/eeprom is Ok but address is non-standard
2. ffs/eeprom is damaged and can't be detected
3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make full flash backup for emergency case
3. repeat required operation
Are you sure that detected ffs/eeprom address is correct ?
autodetected ffs/eeprom address confirmed by user: 00290000
detecting ffs/eeprom size...
ffs/eeprom size: 00D70000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00290000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: _ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\_ffs_20100329-034230.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
rom info: unknown structure: 00
rom info detection finished
code offset: 00000000
ffs/eeprom address can not be detected, value from database assigned: 00290000/00D70000
sec info (fast) detection...
usb bootloader (file) is absent
startup code area #1 check...
startup code area #1 fixed
detecting startup code area #2...
startup code area #2 is absent
Area: Firmware
Write: Firmware
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 63 min 50 sec
Remove/Install battery now !
Old 03-30-2010, 05:00   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
but was it working when you get it?
hello!
you must open with notepad operation.log file which is located in Chinese Miracle folder.
scrool it from up from end and find First operation with this phone.
there you will see Original software version. Post it here
Old 03-30-2010, 14:28   #3 (permalink)
nadirghazi's Avatar
Member: 779665
Sonork: 100.1581784
Thanks Meter: 492
i have many files how to check?it was working but it has restart problem here is the screen shot
Old 03-30-2010, 17:24   #4 (permalink)
Member: 148515
hello!
operation Text file
open it and by date/time find first operation with this phone.
after that you will be able to find proper flash file
plzz help chines wont turn on nadirghazi Infinity-Box 7 01-23-2010 12:17
dead v360? white screen on bootloader, wont turn on javalino Motorola P2k 1 09-08-2007 20:53
L6 wont turn on lights on and off , plugged in works fine HELP!! crunchtime2k Motorola Hardware Repair 6 09-07-2006 18:57
3310 wont turn on? Beef Nokia Hardware & Hardware Repair 1 02-08-2002 15:31
3310 wont turn on Beef Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 02-08-2002 10:10
Page generated in 0.16014 seconds with 9 queries
