11-14-2007, 21:26 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Inside facebook Age: 47
Member: 250468 Status: Offline Sonork: 100.110362 Thanks Meter: 96 | CECT T689 says "ERROR" and second sim mot solved My CECT T689 second sim not solved, phone display "error" when power off. I try complete format and format ffs for both cpu still same. Here I post log of 2nd cpu flash !!! Code: COM7 [VCP1] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: write NOR flash "smart write" active write: Firmware skip: Customization skip: Language Pack skip: Eeprom Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6205:8B00]... boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E221A2200:101C0E00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2200:101C0E00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb detecting chip #02 in region #00... flash: 01227E221A2200:101C0E00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb detecting chip #03 in region #00... flash: 01227E221A2200:101C0E00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... 115200 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E221A2200:101C0E00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2200:101C0E00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb it's time to stop: 10680E1C01781F1C022905D128490978022901D10020F8BD number of flash chip/regions detected: 01/01 total flash region size: 00400000 detecting eeprom area in 1 chip(s)... flash: 01227E221A2200:101C0E00000000 checking area[00000000]: 00000000-003FFFFF... Can't detect eeprom area Do you want to use standard eeprom address: 00380000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard eeprom address selected by user detecting eeprom size... eeprom size: 00080000 eeprom chip: 00 eeprom area: 00000000:00380000-003FFFFF reading [eeprom]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom_20071114-201205.B0E.bin flash: 01227E221A2200:101C0E00000000 Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... detect device identification, method #1... detection phase #1... . detection phase #2... ................................................................ warning: identification information not found, possible reasons: .old firmware type w/o identification data .damaged firmware .damaged hardware detect device parameters finished Area: Firmware flash: 01227E221A2200:101C0E00000000 Write: Firmware protocol ver: 02 ver. sw1: E550AGENT_S1_E550_GSM_MT6205B_DN.01_5.BIN ver. sw2: E550AGENT_S1.01.5 ffs offset/size: 00E00000/00200000 Write Done Finished, time used: 704 sec Remove/Install battery now ! |
11-17-2007, 23:28 | #2 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Narnia Age: 44
Member: 236667 Status: Offline Thanks Meter: 12 | The second CPU should never be flashed! I said not once...the second cpu is a parasite one: in that second flash ic there are only the basic algo,RF data data and startup software.The operating software(if second sim is detected) is obtained from main flash ic.And this china units they are newer the same so the basic content may and usually is different.The solution to your problem is write back up,if you made one... The solution to second sim problem is : format full then write imei(from the back label).If it`s not working it can be hardware problem(sim reader error,Bluetooth malfunction and RF ic) |
12-12-2007, 12:18 | #5 (permalink) | |
Insane Poster Join Date: Dec 2004 Age: 46
Member: 97553 Status: Offline Thanks Meter: 1 | Quote:
01-10-2008, 01:10 | #8 (permalink) | |
Freak Poster Join Date: Aug 2003 Location: Bulgaria Age: 45
Member: 37317 Status: Offline Thanks Meter: 8 | Quote:
hi, did you solve the problem , 'couse I have two pieces with same problem here- "Error " message appears when turning the phone off. I already formatted both FFS, fullflashed first and second CPU( readed flashes from completly working handset), rebuild both IMEI's but the problem still persist. Any ideas are welcome b.r | |
01-10-2008, 01:13 | #9 (permalink) | |
Member: 250468 Status: Offline Sonork: 100.110362 Thanks Meter: 96 | Quote:
But try to remove bluetooth IC (samsung labeled IC) and post result. | |
02-12-2008, 03:45 | #10 (permalink) |
No Life Poster Join Date: Jun 2004 Location: MACEDONIA
Member: 67805 Status: Offline Thanks Meter: 364 | I can't make "complete format" on second cpu useing tx_b rx_b because always I get "error writeing at address..." at first address. Also I can make backup of eprom but I can't write to phone because of same error. I try every sugestion by Infinity soft, and I try every other option like lower baudrate and... Second sim don't work at all. First sim is ok and I make repair of imei Could be this a hardware problem? and what action to take? |
Cect T689 flash ...dual sim | alunecosu_hd | Infinity-Box | 7 | 02-23-2010 21:20 |
T689 second sim is going off | zoki | Infinity-Box | 40 | 05-01-2008 16:22 |
Problem with Second mcu(SIM B) for CECT t689????? | salim00dz | Chinese Cocktail | 32 | 04-17-2008 09:02 |
cect t689 second sim | tenma | Infinity-Box | 1 | 01-05-2008 19:03 |
CECT T689 dual sim PDA Phone | crvkva10 | HTC & PDA WM( With Touchscreen) | 1 | 07-12-2007 08:31 |
