Chinese 1600 flight mode sulotion 100% tested Hello infinity can solve chinese 1600 flight mode problem just in minuts. here is the log. after format if you see bad software then use repair bad software option simple. :) >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> >>>> COM7 [VCP0] selected module v2.68 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:E63D:000C boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 230400 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: TOP23_07A_PCB01_GPRS_MT6223P_S00.N1112_V5_53.BIN ver. sw 2: N1112_V5.53, 00000000 ffs offset/size: 00700000/00100000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00700000 flash: EC257E25062501:2AEA0000000000 checking area [00000000]: 00000000-007FFFFF... eeprom/ffs found near: 00700000 detecting eeprom/ffs size... eeprom/ffs size: 00100000 ffs chip: 00 eeprom/ffs area: 00000000:00700000-007FFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[TOP23_07A_PCB01_GPRS_MT6223P_S00.N1112_V5_53.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[TOP23_07A_PCB01_GPRS_MT6223P_S00.N1112_V5_53.BIN]_20081109-124251.B0E.bin flash: EC257E25062501:2AEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done write ... write Done Finalization ... formatting... flash: EC257E25062501:2AEA0000000000 Finalization Done Finished, time used: 94 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! COM7 [VCP0] selected module v2.68 Action: repair "bad software" Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:E63D:000C Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E04 Date: 2000.00.00 Version: 1.0 Version: N1112_V5.53 Version: detecting structure #2... 0Done 44 byte(s) read imei: 35935300337233 connection Ok detecting structure #6 (mode-1)... 0Done 181 byte(s) read writing data... verification... verification Ok Finished, time used: 13 sec Remove/Install battery now ! |
good test report Br Faisal_Computer |
good work infinity rocks always providing good solutions |
hello! thank you for sharing your experience!!! |
thanks good sharing bro, |
why i cant repair my 1600 china phone problem is flight mode after format bad software i did the same process but still bad software |
nice referrence bro job well..thanks... |
Post Here Photo.......... |
thank you! nice sharing.keep it up! |
Did you tried to make "repair bad software" operation ? |
After complete foprmating press repair bad software its okkkkkkkkkkkk 100%%%%%%%%% |
can u tell me plz that which cable do u use for 1600? |
@ Nawab Traders what is the pinout used? |
sir can u share which cable or pinout u follow. plz help |
