11-09-2008, 08:50 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Roof of the world
Member: 209722 Status: Offline Thanks Meter: 818 | Chinese 1600 flight mode sulotion 100% tested infinity can solve chinese 1600 flight mode problem just in minuts. here is the log. after format if you see bad software then use repair bad software option simple. >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> >>>> COM7 [VCP0] selected module v2.68 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:E63D:000C boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 230400 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: TOP23_07A_PCB01_GPRS_MT6223P_S00.N1112_V5_53.BIN ver. sw 2: N1112_V5.53, 00000000 ffs offset/size: 00700000/00100000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00700000 flash: EC257E25062501:2AEA0000000000 checking area [00000000]: 00000000-007FFFFF... eeprom/ffs found near: 00700000 detecting eeprom/ffs size... eeprom/ffs size: 00100000 ffs chip: 00 eeprom/ffs area: 00000000:00700000-007FFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[TOP23_07A_PCB01_GPRS_MT6223P_S00.N1112_V5_53.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[TOP23_07A_PCB01_GPRS_MT6223P_S00.N1112_V5_53.BIN]_20081109-124251.B0E.bin flash: EC257E25062501:2AEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done write ... write Done Finalization ... formatting... flash: EC257E25062501:2AEA0000000000 Finalization Done Finished, time used: 94 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! COM7 [VCP0] selected module v2.68 Action: repair "bad software" Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:E63D:000C Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E04 Date: 2000.00.00 Version: 1.0 Version: N1112_V5.53 Version: detecting structure #2... 0Done 44 byte(s) read imei: 35935300337233 connection Ok detecting structure #6 (mode-1)... 0Done 181 byte(s) read writing data... verification... verification Ok Finished, time used: 13 sec Remove/Install battery now ! |
The Following 4 Users Say Thank You to CONCORDIA GSM For This Useful Post: |
11-10-2008, 18:30 | #11 (permalink) |
Freak Poster Join Date: Feb 2007 Location: PATHAN MUNDA
Member: 445967 Status: Offline Sonork: 100:1652029 Thanks Meter: 37 | After complete foprmating press repair bad software its okkkkkkkkkkkk 100%%%%%%%%% |
The Following User Says Thank You to shmily For This Useful Post: |
11-10-2008, 18:46 | #12 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Afghanistan Kabul
Member: 295886 Status: Offline Sonork: 100.1583369 Thanks Meter: 1,472 | can u tell me plz that which cable do u use for 1600? |
The Following User Says Thank You to Maiwand khan For This Useful Post: |
1202-1203-1661-1662 not charging test mode and local mode solution 100% tested | /\/\A/\/| | Nokia Hardware & Hardware Repair | 14 | 07-11-2011 05:49 |
Kais 130 final sulotion 100% test | anam120 | HTC & PDA WM( With Touchscreen) | 15 | 11-15-2009 17:42 |
1110,1112,1600,2310 contact service 100% tested solution | khan_mobiles | HWK | 1 | 09-07-2008 11:12 |
BB5 Offline Mode Soulution 100% Tested | imran_mz1 | Nokia Hardware & Hardware Repair | 16 | 06-25-2008 13:31 |
Chinese N92 Restart solution Working 100% Tested | srini.unique | ET-BoX | 3 | 11-15-2007 14:27 |
