Old 04-19-2008, 19:16   #1 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 1,008
chinese 6188 shutdown on logo
i have chinese 6188(back label), n91s(front).which is come to me in fault of shut down on startup logo.i check it on power supply that when its screen blank but power supply shows power on means voltage indicatars rotate as rotate in normal phones.i format(complete)it but same condition.plz give me the solution for this.i also email flash file eeprom backup file and log file to [email protected].
Old 04-19-2008, 19:32   #2 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 1,008
here is flashbackup logs
OM3 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: read NOR flash
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:ADC1C9E
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: E:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.49FF0391.[SZMI26_05C_ELITEK_PCB01_GPRS_MT6226_S01.SZMI26_S60 8L_ISES_D770_V2_0.BIN_42B2CA40].rpl
New firmware detected:
- make "Read full flash" operation
- send "backup_system_log_..." file to support: [email protected]
- send flash backup file(s) to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: 49FF0391
identification#1 protocol ver: 04
ver. sw1: SZMI26_05C_ELITEK_PCB01_GPRS_MT6226_S01.SZMI26_S60 8L_ISES_D770_V2_0.BIN
ver. sw2: SZMI26_S608L_ISES_D770_V2.0, BF354DBD
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading [flash[SZMI26_05C_ELITEK_PCB01_GPRS_MT6226_S01.SZMI26_S60 8L_ISES_D770_V2_0.BIN]]...
file saved: E:\Documents and Settings\sa40\Desktop\backup_flash[SZMI26_05C_ELITEK_PCB01_GPRS_MT6226_S01.SZMI26_S60 8L_ISES_D770_V2_0.BIN]_20080419-225041.B0M.bin
file saved: E:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _49FF0391_SZMI26_05C_ELITEK_PCB01_GPRS_MT6226_S01. SZMI26_S608L_ISES_D770_V2_0.BIN_42B2CA40_20080419-225110.B0X.bin
Finished, time used: 1699 sec
Remove/Install battery now !
Old 04-19-2008, 21:47   #3 (permalink)
Member: 148515
Thanks Meter: 14,718
hello!
same working phone must be found in order to reapir this faulty one.
read full backup and send to me, i will process it and upload to support
also you can use same backup for flashing
Old 04-20-2008, 07:55   #4 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 1,008
hello!
means i read full flash backup and write as it is without sent u for processing.because i have no same working phone.
Old 04-20-2008, 12:02   #5 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 1,008
now i also upload it on RAPIDSHARE. if processing neccesary for flash in infinity then process it.this file from faulty mobile backup.
Old 04-20-2008, 20:08   #6 (permalink)
Member: 148515
hello!
i dont need faulty backup, i cant upload it to support.
find good working phone and get it's firmware
Old 04-21-2008, 08:15   #7 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 1,008
thanks sir i will try to find working phone.
Old 04-22-2008, 16:50   #8 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 1,008
sir i found working phone now.only flash backup require or eeprom and other backup also require.and how i send u.ulpoad on rapidshare or mail u on [email protected].
Old 04-22-2008, 18:27   #9 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 1,008
upload on rapidshare when support team online check it.
http://rapidshare.com/files/10957148...422-21051.html
http://rapidshare.com/files/10957227...2_0.BIN_4.html
http://rapidshare.com/files/10957246...0422-2110.html
Old 04-22-2008, 20:04   #10 (permalink)
Member: 148515
hello!
will process this files today and upload to support
Old 04-23-2008, 14:23   #11 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 1,008
sir i download files from support and flash but no changing.write EEPROM but same.FULL FORMAT but same.sir now whats the next step now.
Old 04-23-2008, 19:16   #12 (permalink)
Member: 148515
hello!
those 2 files (main+eeprom) is old.
I cant process flash backup from rapidshare.
can you read backup one more time and upload it in rar archive?
Old 04-24-2008, 10:44   #13 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 1,008
sir i have backup files of working phone in my computer.
now where i upload it.i dont understand "in rar archive". sorry
Old 04-24-2008, 20:08   #14 (permalink)
Member: 148515
hello!
make archive by RAR archivator and upload to www.rapidshare.com
Old 04-26-2008, 19:05   #15 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 1,008
http://rapidshare.com/files/11060742...flash.rar.html
http://rapidshare.com/files/11060771...eprom.rar.html
here is the new link
N72 on battery hang on logo NOKIA Tygiel1 Nokia Hardware & Hardware Repair 2 03-14-2010 12:47
6270 works well on 900mhz but auto shutdown on 1800mhz syed.n Nokia Hardware & Hardware Repair 1 01-06-2008 07:00
Startup and shutdown screen logo pgtl Cruiser Suite 1 08-02-2005 23:37
removing D500 startup and shutdown animation/logo g0tcha SWIFT Platform 0 04-20-2005 10:48
Page generated in 0.42468 seconds with 8 queries
