chinese 6280 rm-78 COM22 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:CD41:CD24 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.4DF40BA7.[V830_E44_PCB01_GPRS_MT6226_S01.369_SUM_KGM526A0_1_ 1.BIN_BF973831].rpl ==================== New firmware detected: V830_E44_PCB01_GPRS_MT6226_S01.369_SUM_KGM526A0_1_ 1.BIN - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: 4DF40BA7 identification#1 protocol ver: 04 ver. sw1: V830_E44_PCB01_GPRS_MT6226_S01.369_SUM_KGM526A0_1_ 1.BIN ver. sw2: V830_E44.369.SUM.KGM526A0_1.1, CEC76840 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00710000 Detected eeprom/ffs address is non-standard: 00710000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00710000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 008F0000 ffs chip: 00 eeprom/ffs area: 00000000:00710000-00FFFFFF detecting ffs structure pass 1... .................. detect standard fat location pass #1... ............................. detect extended fat location pass #1... ............................. fat location can't be detected ffs element #1 detection failed detecting ffs structure pass 2... .................. detect standard fat location pass #1... ............................. detect extended fat location pass #1... ............................. fat location can't be detected ffs element #2 detection failed Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_4DF40BA7_V830_E44_PCB01_GPRS_MT6226_S01. 369_SUM_KGM526A0_1_1.BIN_BF973831_20081013-110335.B0X.bin Finished, time used: 178 sec Remove/Install battery now ! i need flash file chinese 6280 rm-78 |
damage eeprom........ |
hello! what problem with phone? format ffs is not helpful? |
help me phone not on plz help me |
please try format FFS in COMPLETE mode and post here result |
