Old 10-13-2008, 07:12   #1 (permalink)
Member: 700923
Thanks Meter: 13
Question chinese 6280 rm-78
COM22 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: read/check detailed information
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:CD41:CD24
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
921600
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.4DF40BA7.[V830_E44_PCB01_GPRS_MT6226_S01.369_SUM_KGM526A0_1_ 1.BIN_BF973831].rpl
New firmware detected:
- make "Read full flash" operation
- send "system_log_..." file to support: [email protected]
- send flash backup file(s) to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: 4DF40BA7
identification#1 protocol ver: 04
ver. sw1: V830_E44_PCB01_GPRS_MT6226_S01.369_SUM_KGM526A0_1_ 1.BIN
ver. sw2: V830_E44.369.SUM.KGM526A0_1.1, CEC76840
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00710000
Detected eeprom/ffs address is non-standard: 00710000
Posible reasons:
1. eeprom is Ok but address is non-standard
2. eeprom damaged and can't be detected
3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make flash backup for emergency case
3. repeat required operation
Are you sure that detected eeprom address is correct ?
autodetected eeprom/ffs address[00710000] confirmed by user
detecting eeprom/ffs size...
eeprom/ffs size: 008F0000
ffs chip: 00
eeprom/ffs area: 00000000:00710000-00FFFFFF
detecting ffs structure pass 1...
detect standard fat location pass #1...
detect extended fat location pass #1...
fat location can't be detected
ffs element #1 detection failed
detecting ffs structure pass 2...
ffs element #2 detection failed
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_4DF40BA7_V830_E44_PCB01_GPRS_MT6226_S01. 369_SUM_KGM526A0_1_1.BIN_BF973831_20081013-110335.B0X.bin
Finished, time used: 178 sec
Remove/Install battery now !
i need flash file chinese 6280 rm-78
Old 10-13-2008, 07:30   #2 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,732
Exclamation
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed disabled
Boot Done
Initialize...
Initialize Done
Set baud...
921600
Set baud Done
device-id: 4DF40BA7
Posible reasons:
ffs chip: 00
damage eeprom........
Old 10-13-2008, 21:17   #3 (permalink)
Member: 148515
Thanks Meter: 13,888
hello!
what problem with phone? format ffs is not helpful?
Old 10-14-2008, 06:34   #4 (permalink)
Member: 700923
Thanks Meter: 13
help me
phone not on plz help me
Old 10-14-2008, 18:30   #5 (permalink)
Member: 148515
hello!
please try format FFS in COMPLETE mode
and post here result
chinese 6280 rm-78 w850 Infinity-Box 1 10-12-2008 21:49
chinese 6280 rm-78 w850 Infinity-Box 1 10-10-2008 16:31
Does unlocking 6288 RM-78 is the same as 6280 RM-78 samuelscu BB5BOX 0 09-24-2007 21:49
Nokia 6280 RM-78 - SW 3.40 need !!!! m.com Nokia Base Band 5 ( BB-5 ) 4 07-10-2006 16:05
6280 RM-78 Flashing Russian on it drancill Nokia Base Band 5 ( BB-5 ) 0 02-27-2006 18:29
Page generated in 0.29769 seconds with 8 queries
