10-19-2007, 10:10 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Chinese Blue Tooth 2.0 Not Connecting Blue Tooth 2.0 Is Written On It And It Comes With An External Zoom I Need Working Pinout For This Phone |
10-19-2007, 13:34 | #4 (permalink) |
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | the connecter is 12 pin d800 socket charging socket is on the bottom of the phone the ground is located in the 5 point Last edited by sahil2000ind; 10-19-2007 at 13:41. |
10-19-2007, 13:49 | #7 (permalink) |
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | COM6 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read eeprom Boot... Press and HOLD Power button now ! baud autodetection active 9600 Connecting, wait... error: boot phase#2/1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 2 sec Remove/Install battery now ! WHAT IS THIS ERROR here is the log of the phone when i connect it to infinity |
10-19-2007, 14:21 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @sahil2000ind your problem: wrong pinout, please, read info below @all Dear Friends, I have spend several hours this night and I have prepared extra-mega-detailed instruction and explanation especially for you so nobody can say to me that I am lazy. How about others ? Due to a lot of different models with the same name but absolutely different hardware, bottom connectors and different pinouts we recommend you to include the next info: 1. detailed description of model 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ if not helps, please read: http:///vbb/showpo...36&postcount=7 if not helps, please read: http:///vbb/showthread.php?t=433447 |
10-19-2007, 14:51 | #9 (permalink) |
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | i have connected the pins in about 36 different ways but it say the same problem i dont feel lazy but i want that is any one have done it the they can help me in finding the right pinouts thats why i have putted the picture of this phone BUT SEEMS THAT I AM UNABLE TO FIND THE RIGHT PINOUTS |
10-19-2007, 15:37 | #10 (permalink) |
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Got The Right Pinouts CHINESE BLUE TOOTH 2.0 WITH ZOOM 9-grnd 8- Rx -tx 7- Tx-rx Last edited by sahil2000ind; 10-19-2007 at 15:44. |
10-20-2007, 15:54 | #15 (permalink) |
No Life Poster Join Date: May 2004 Location: India
Member: 65074 Status: Offline Sonork: 100.1611263 Thanks Meter: 214 | The Rx & Tx are Printed on Board Just Above The B sim(U Need To open the handset). Please Read the full Flash & EEprom & Send it to [email protected] I need it Urgently. Thanks & Regards Shubhanshu |
Blue tooth 2.0 bad software after format | nilan | SpiderMan | 3 | 05-15-2008 08:04 |
blue tooth 2.0 bad software | Imrankhan | Infinity-Box | 6 | 05-12-2008 13:31 |
China Mobile Blue Tooth 2.0 | RASHED SAM | Chinese Models & Cloned Phones | 2 | 04-22-2008 07:24 |
Chines phone Blue Tooth 2.0 LV918 | now_mobiles | Infinity-Box | 5 | 11-02-2007 16:24 |
