05-26-2008, 09:00 | #1 (permalink) |
No Life Poster Join Date: Jul 2007 Location: Dubai, UAE Age: 38
Member: 547967 Status: Offline Thanks Meter: 653 | Successfully Flashed & Unlocked Kp130 Credits goes to Infinity Team Good Team. COM9 [Serial2] selected Device: LG KP130 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Skip: Alchemy data Skip: Eeprom "smart write" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:F0EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 921600 Set baud Done Check flash... current eeprom imei: 35212--------------- file saved: C:\Program Files\InfinityBox\LGA\eeprom_352126--------4_LG KP130_20080526-004959.B1E.bin ........ version: - Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) flash: 01227E22212200:F0EA0000000000 flash: 01227E22212200:00000000000000 write: 2nd chip area Write Done Finished, time used: 101 sec Remove/Install battery now ! COM9 [Serial2] selected Device: LG KP130 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 921600 Set baud Done Check flash... current eeprom imei: 352126---------- file saved: C:\Program Files\InfinityBox\LGA\eeprom_35212----------_LG KP130_20080526-005306.B1E.bin ........ version: - Check flash Done Check space... current eeprom imei: 352126---------- ................................ finalization done Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 Write Done Finished, time used: 35 sec Remove/Install battery now ! |
The Following User Says Thank You to mujahid_ali For This Useful Post: |
05-26-2008, 13:22 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Here is KP130 cable information: keyboard top 1.........18 1: Gnd 2: phone Rx (RJ45 pin-2) 3: phone Tx (RJ45 pin-3) 5: Gnd 15: Gnd 18: Gnd |
05-26-2008, 16:27 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Yes, you can. Here is an instruction: http:///vbb/showthread.php?t=526956 |
successfully flash & unlock 2600c with 5.61v | shimul_777 | J.A.F. By Jafsupport.com | 1 | 03-07-2009 08:31 |
w850 successfully flash & unlock by D-Client | rea1One | D-Unlock Suite | 11 | 09-30-2007 23:37 |
is GR1000 supported by infinity? for flashing & unlocking & which cable??? | ReyTech | Infinity-Box | 8 | 05-07-2007 00:13 |
***Successful Flashing & Unlocking Z150 whit UST-Pro2 v2.50 :)*** | bhgsmservis | UST Pro II | 1 | 07-26-2006 16:30 |
