04-27-2007, 11:16 | #1 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 312863 Status: Offline Thanks Meter: 2 | motorola c168,pls help Device: C168 Checking data, wait... Action: Flash write "smart write" active Write: Firmware Write: Flex Write: Language Pack Skip: FFS/File system Write: Images Write: Melody Skip: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 1490-000 HW ver: TCT-9- Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:886400010001 flash: Intel 28F640W18-T T 8Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0089:886400010001 flash: Intel 28F640W18-T T 8Mb Write: Flex flash: Intel 28F640W18-T T 8Mb Write: Language Pack flash: Intel 28F640W18-T T 8Mb Write: Images flash: Intel 28F640W18-T T 8Mb Write: Melody flash: Intel 28F640W18-T T 8Mb Writing Done Finished, time used: 29 sec Remove/Install battery now ! please help |
05-22-2007, 10:28 | #5 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bangladesh
Member: 387110 Status: Offline Sonork: Not Use Thanks Meter: 630 | Hello all, Facing problem flashing motorola c168, here under I paste log :- --------------------------------------------------------- COM5 selected Device: C168 Checking data, wait... Action: Flash write "smart write" active Write: Firmware Write: Flex Write: Language Pack Skip: FFS/File system Write: Images Write: Melody Skip: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 1390-000 HW ver: TCT-9- Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:886400010001 flash: Intel 28F640W18-T T 8Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0089:886400010001 flash: Intel 28F640W18-T T 8Mb error: error flash vpp try#1 to recover write error at 00000000 error: flash end try#2 to recover write error at 00000000 error: answer#00 try#3 to recover write error at 00000000 error: answer#00 try#4 to recover write error at 00000000 error: answer#00 try#5 to recover write error at 00000000 error: answer#00 try#6 to recover write error at 00000000 error: answer#00 try#1 to recover write error at 00002000 error: answer#00 try#2 to recover write error at 00002000 error: answer#00 try#3 to recover write error at 00002000 error: answer#00 try#4 to recover write error at 00002000 error: answer#00 try#5 to recover write error at 00002000 error: answer#00 try#6 to recover write error at 00002000 error: answer#00 try#1 to recover write error at 00004000 error: answer#00 try#2 to recover write error at 00004000 error: answer#00 try#3 to recover write error at 00004000 error: answer#00 try#4 to recover write error at 00004000 error: answer#00 try#5 to recover write error at 00004000 error: answer#00 try#6 to recover write error at 00004000 error: answer#00 try#1 to recover write error at 00006000 error: answer#00 try#2 to recover write error at 00006000 error: answer#00 try#3 to recover write error at 00006000 error: answer#00 try#4 to recover write error at 00006000 error: answer#00 try#5 to recover write error at 00006000 error: answer#00 try#6 to recover write error at 00006000 error: answer#00 try#1 to recover write error at 00008000 error: answer#00 try#2 to recover write error at 00008000 error: answer#00 try#3 to recover write error at 00008000 error: answer#00 try#4 to recover write error at 00008000 error: answer#00 try#5 to recover write error at 00008000 error: answer#00 try#6 to recover write error at 00008000 error: answer#00 try#1 to recover write error at 0000A000 error: answer#00 try#2 to recover write error at 0000A000 error: answer#00 try#3 to recover write error at 0000A000 error: answer#00 try#4 to recover write error at 0000A000 error: answer#00 try#5 to recover write error at 0000A000 error: answer#00 try#6 to recover write error at 0000A000 error: answer#00 try#1 to recover write error at 0000C000 error: answer#00 try#2 to recover write error at 0000C000 error: answer#00 try#3 to recover write error at 0000C000 error: answer#00 try#4 to recover write error at 0000C000 error: answer#00 try#5 to recover write error at 0000C000 error: answer#00 try#6 to recover write error at 0000C000 error: answer#00 try#1 to recover write error at 0000E000 error: answer#00 try#2 to recover write error at 0000E000 error: answer#00 try#3 to recover write error at 0000E000 error: answer#00 try#4 to recover write error at 0000E000 error: answer#00 try#5 to recover write error at 0000E000 error: answer#00 try#6 to recover write error at 0000E000 Writing Fail Finished, time used: 441 sec Remove/Install battery now ! --------------------------------------------------------- What is my fault, please help. Thanks/ |
motorola c168 plssss help................ | rk19801 | Infinity-Box | 1 | 07-05-2008 11:51 |
motorola C168 dead help | therocky8 | Infinity-Box | 3 | 11-29-2006 10:35 |
How to flash motorola V60? pls help | Maurone | Smart-Clip | 4 | 07-27-2005 22:16 |
All motorola whiz pls help | eeprom_flash | Motorola P2k | 0 | 08-06-2004 14:03 |
2 motorola V70 pls help me with codes | melsoft | Phone Unlocking Codes & Maps | 1 | 07-15-2003 07:28 |
