Old 04-21-2008, 11:07   #1 (permalink)
Member: 364815
Thanks Meter: 68
chinese cect k808 booting error
hi infinity team,
i hv a chinese cect k808 handset ,complaint with
when trying to power on display blinking
iwas tried with format ffs and flashing also but bootin error
tried with boudrate autodetect celect but same problem
log is given below
COM4 [VCP0] selected
Action: reset settings
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
error: boot phase#2/1 failed
Can't initialize test mode !
Possible reasons:
1. communication fault, repeat required operation
2. eeprom/ffs serious damaged, use repair eeprom/ffs files or use other unlock/format method
error: operation failed !
Finished, time used: 78 sec
Remove/Install battery now !
plz help me infinity team
b/r
sushil
Old 04-21-2008, 16:20   #2 (permalink)
Member: 148515
Thanks Meter: 13,684
hello!
try format in complete mode, if not work- post error log
Old 04-25-2008, 15:41   #3 (permalink)
wsw243's Avatar
Member: 248050
Sonork: 100.1624328
Thanks Meter: 139
Phone off with SiM try format:safe than blinking so try format:complete and phone work but still on first position that power off with SiM. Plz infinity team suggest my phone is I-Mobile W816 connector 1x8 pin 3rx 4tx 5gnd here is log
COM7 [VCP0] selected
Device: Autodetect 6205-6227 NOR
eeprom backup enabled, it may takes several minutes !
Action: reset
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:3421:4B92
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: 01227E22202200:29EA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: YJG_V470_01_PCB01_GPRS_MT6226_S01.BIN
ver. sw2: L354201.6.20.1.0T22M1216_M451A, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading [eeprom[YJG_V470_01_PCB01_GPRS_MT6226_S01.BIN]]...
file saved: E:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[YJG_V470_01_PCB01_GPRS_MT6226_S01.BIN]_20080425-182003.B0E.bin
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
Finished, time used: 376 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 04-25-2008, 16:25   #4 (permalink)
Member: 148515
hello!
worth to try flashing, but no such flash file in our collection...
do you have same model working phone on your local market?
would be nice to get it for reading backup.
you can use it for restore own phone as well as add to our collection
Need mpeg4 necom n930 ve cect k808 pinout tornado73 Infinity-Box 3 01-03-2008 12:09
hi pleas pinout cect k808 bibooo Infinity-Box 1 01-02-2008 20:40
cect K808 2sim restart with sim farshid-jan Infinity-Box 7 12-27-2007 10:44
need flash files china cect k808 mp4 helloabuussama Chinese Models & Cloned Phones 0 12-10-2007 11:08
CECT K808 format FFS ok but callibration screen?????? .::BHATTI::. Infinity-Box 5 10-24-2007 17:00
Page generated in 0.28603 seconds with 8 queries
