02-06-2008, 12:20 | #5 (permalink) |
Freak Poster Join Date: Nov 2007
Member: 623972 Status: Offline Thanks Meter: 26 | chinese handset u 90 i have u 90 chinese,the problem is ,it shows headset icon on the display,and headset works ,ringer is ok,but when we disconnected the headset , but profile does not change.when i go to profile menu ,there is not ACTIVATE option,it shows only CUSTOMIZE....this fault came after connected the wrong charger in the handset,,,....what should to do exactly ,i have also change the IC MT 6305,PLACED Under the keypad board. |
02-06-2008, 20:05 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! ofcource you can try to make full backup and then formating (safe& complete) but i think you must search for error in semiconductors which are used in bottom connector circuit |
05-23-2010, 09:40 | #10 (permalink) |
No Life Poster Join Date: Jul 2009 Location: India
Member: 1086393 Status: Offline Thanks Meter: 771 | Hi, Must Solve with complete ffs method, if fail,then try flash with same fone flash file/ search on support. |
The Following User Says Thank You to Riteshgpt60 For This Useful Post: |
1200 battery low or battery empty at incoming time | bala5505 | Nokia Hardware & Hardware Repair | 4 | 12-28-2009 17:31 |
1110 battery low problem and battery empty | kashif_khatri | Nokia Digital Core Technology 4 ( DCT-4 ) | 11 | 08-09-2009 14:52 |
All chinese handset Service codes!!!!! | Softway | Infinity-Box | 2 | 06-07-2007 17:30 |
Battery empty, Bosch 509, but the battery is still full | calinsand | Various | 7 | 07-25-2004 00:20 |
GD52 Dead, after unlock with battery empty | gsm flying free | Panasonic | 3 | 10-10-2001 08:45 |
