<<< Chinese Miracle 2.91 Touchscreen Calibration Improvement >>> i have china mobile with touchscreen calibration fault, try all methods , format safe & full try other all posibilites but allways failed, now in this new verion of chinse mircle successfull pass the tocuhscreen calibration test, big improvement by infinity team. ::::::::::: LOG :::::::::::: COM4 [VCP0] selected module v2.91 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... full flashCKT26_06B_PCB01_GPRS_MT6226_S01.DINOSAUR6_26B _YR_L7EN_205_071116_LD_OV0_SS75_CTF_BT_06B__fullfl ash_20090925-131827.B0M loaded detected record size adjusted detected record size adjusted detected record size adjusted Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:93AC:F56E status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: DINOSAUR6_26B_YR_L7EN_205_071116_LD_OV0_SS75_CTF_B T_06B Version: CKT26_06B_HW 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok 512 byte(s) read 158 byte(s) read reading data #2... reading data #3... 512 byte(s) read writing data... verification... verification Ok Finished, time used: 18 sec Remove/Install battery now ! |
Good work bro............ |
