09-17-2014, 13:59 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Chinese Miracle-2 : MTK/MediaTek : Android Flashing : Code: Load File File_Info : ckt82_we_kk FileVersion : MT6582 Load File Ok Operation : Flash [ v1.00 ] ======= Flash Files set for flashing : [ MCU ] : MT6582__HIGHSCREEN__Zera_F__Android_4.4.2__20140624_081855.ispff 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 85 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Processing DA stage NAND_ID : 00000000000000000000 eMMC_ID : 11010030303447393051641B22B41159 DA Stat : v4.2 on BBID : 0x87 eMMC FlashIC initialized [eMMC] : FLASH_VEN : 09G40 [eMMC] : FLASH_CID : 5911B4221B6451303947343030000111 [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Brand : highscreen ProdName : Zera F ProdModel : Zera F Device : Zera F AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ZERA01A-S10A_VOBIS_L9RU_204_140624161854 Flash pre-erase enabled Erase Flash now ... Flash pre-erase done Write Flash now ... [ MCU ] : MT6582__HIGHSCREEN__Zera_F__ZERA01A-S10A_VOBIS_L9RU_204_140624161854__Android_4.4.2__20140624_081855.ispff Init Ok , Sending blocks ... Write done , 3776 blocks sent Done! Elapsed: 00:12:12 Reconnect Power/Cable! Code: Operation : Format FileSystem [ v1.00 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 85 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Processing DA stage NAND_ID : 00000000000000000000 eMMC_ID : 11010030303447393051641B22B41159 DA Stat : v4.2 on BBID : 0x87 eMMC FlashIC initialized [eMMC] : FLASH_VEN : 09G40 [eMMC] : FLASH_CID : 5911B4221B6451303947343030000111 [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : Already exist FMT Mode set to : 0 Format : Cache and UserData (Full Factory Reset) Other : Set SpecFTM Format CACHE block Format block Ok! Format UDA block Format block Ok! Done! Elapsed: 00:00:15 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.00 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 85 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Processing DA stage NAND_ID : 00000000000000000000 eMMC_ID : 11010030303447393051641B22B41159 DA Stat : v4.2 on BBID : 0x87 eMMC FlashIC initialized [eMMC] : FLASH_VEN : 09G40 [eMMC] : FLASH_CID : 5911B4221B6451303947343030000111 [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Read Ok , collect info Brand : highscreen ProdName : Zera F ProdModel : Zera F Device : Zera F AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ZERA01A-S10A_VOBIS_L9RU_204_140624161854 Saved to : C:\InfinityBox\CM2MTK\Flash\MT6582__HIGHSCREEN__Zera_F__ZERA01A-S10A_VOBIS_L9RU_204_140624161854__Android_4.4.2__20140624_081855.ispff Done! Elapsed: 00:33:59 Reconnect Power/Cable! CM2 automatically determine file version info , e.g. brand, model, modem version during read and during flashing. CM2 not kill phones during format. CM2 can make and restore relevant data backup ( avoid of weeks/month dump seeking ) P.S. : Flash read/write speed depend on : HDD type and speed , Phone eMMC flash vendor and type. P.P.S : Format have few modes , which bring different results ( e.g. : full reset , or partial ( data , security , but left applications and some settings ) P.P.P.S : It just start |
The Following 9 Users Say Thank You to Dzirt For This Useful Post: |
09-18-2014, 06:07 | #4 (permalink) |
No Life Poster Join Date: Oct 2005 Location: iSiddeque Age: 41
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 428 | @Dzirt Sir, waiting for release. I am Infinity user since started I haven't seen like Infinity team. If have Infinity box do not need other box. B.R. Siddeque. |
09-18-2014, 12:36 | #10 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | MTK 6571 , just got phone on hands : Code: Operation : Check / Read Info [ v1.00 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 85 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Processing DA stage NAND_ID : 002C00BC009000660054 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8B NAND FlashIC initialized [NAND] : FLASH_VEN : 0x006E , [Micron] NAND_MT29C4G48MAAHBAAKS_5WT [NAND] : FLASH_DIE : 002C 00BC 0090 0066 0054 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Elapsed: 00:00:09 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to Dzirt For This Useful Post: |
09-18-2014, 12:43 | #11 (permalink) | |
Freak Poster Join Date: Jan 2013
Member: 1876649 Status: Offline Sonork: 100.1615837 Thanks Meter: 14 | Quote:
please give me beta test my sonork id 100.1614074 | |
