05-06-2015, 16:19 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Madagascar
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | MT6571 nand read error Code: Card found: S/N 334F:0128 Chinese Miracle II [MTK module] v 1.18 Operation : Check / Read Info [ v1.18 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 009800BC009000660076001500010000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... DA start Failed! Check battery , cable , drivers and try try again Boot Error! Operation Failed Elapsed: 00:00:14 Reconnect Power/Cable! Operation : Check / Read Info [ v1.18 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : CA00 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0x00 BLVersion : 0x00 Preloader Status : Not active (Erased) Processing DA stage Error : Correct DA sequence not found for target! Try Re-Install CM2MTK module! Boot Error! Operation Failed Elapsed: 00:00:16 Reconnect Power/Cable! Operation : Check / Read Info [ v1.18 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! Operation : Check / Read Info [ v1.18 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Error while getting CPU info, sync error! Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! Operation : Check / Read Info [ v1.18 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 009800BC009000660076001500010000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0085 , [TOSHIBA] TYBC0A111557KC [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! NAND : Detecting structure now... Please, wait. NAND : Structure detect failed [1F]! Send report to support! Info read not done :( Erased phone or unsupported FlashIc? You can change settings : Settings -> Other -> NAND init Mode Done! Elapsed: 00:01:47 Reconnect Power/Cable! |
05-06-2015, 18:16 | #3 (permalink) |
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | Thanks for help problem solved by selecting P3 init nand mod Code: Card found: S/N 334F:0128 Chinese Miracle II [MTK module] v 1.18 Operation : Check / Read Info [ v1.18 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 009800BC009000660076001500010000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0085 , [TOSHIBA] TYBC0A111557KC [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:11 Reconnect Power/Cable! Operation : Format FileSystem [ v1.18 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 009800BC009000660076001500010000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v0.2 on BBID : 0x8B DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0085 , [TOSHIBA] TYBC0A111557KC [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Format : UserData Only (Factory Reset) Format UDA block Format block Ok! Done! Elapsed: 00:00:14 Reconnect Power/Cable! Thanks |
