11-04-2015, 13:00 | #1 (permalink) |
No Life Poster Join Date: May 2008
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,029 | I8552 mtk 6575 preloader erased problem. Chinese Miracle II [MTK module] v 1.35 Operation : Check / Read Info [ v1.35 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 33 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0000 , OEM : 0000 [eMMC] : FLASH_INF : [eMMC] : FLASH_CID : 00000000000000000000000000000000 [eMMC] : FLASH_EXT : 00000000/00000000 [eMMC] : FLASH_LEN : 0x0000000000000000 INT RAM : 0x00020000 EXT RAM : 0x00000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done Erased phone or unsupported FlashIc? You can change settings : Settings -> Other -> NAND init Mode Done! Elapsed: 00:00:11 Reconnect Power/Cable! i need flash file in bin formate. |
11-04-2015, 14:45 | #2 (permalink) | |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Quote:
phone condition ? i think logs enough EMMC damage | |
