07-04-2015, 21:44 | #1 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Chinese Miracle-2 MTK/MediaTek v1.22 - MT6795, Android 5.x and more MediaTek SP Platform Flash Engine updated - MediaTek MT6795 [HelioX10] Flashing supported Factory FW and Dump flashing - Factory FW writing revised for some platforms - MT67x2 improvements Some improvements and bugfixes Supported CPU for Flash Writing: MT6575, MT6577 eMMC only MT6571, MT6572, MT6582, MT6589, MT6592, MT83xx eMMC only MT6732, MT6752, MT6795, MT8752 eMMC only MT8127 eMMC only Factory FW reading improved - MediaTek MT6795 [HelioX10] Factory FW reading supported No need USB Debug/Root etc. - Big firmware handling improved: MT659x, MT67xx - Factory Firmware size now more compact - up to 2 times for some models Service Operations improved - "Fix Unknown BaseBand" supported for MT6795 - "DLFix" (DL Image Tool Fail error repair) supported for MT6795 - "Flash Erase" supported for MT6795 - NVRAM operations supported for MT6795 - "Format FS" (UDA + CACHE) supported for MT6795 - "Write Flash" / "Read Flash" (DUMP) supported for MT6795 - "Fix DL" during PrivacyLock reset and "Format FS" now made automatically Unlock Operations improved - "Direct Unlock" operation supported for MT6795 - "Read Unlock Codes" operation supported for MT6795 - New models supported Beeline Pro 2 Beeline Smart 3 Beeline Smart 4 Beeline Tab Pro MTS 982T MTS Smart Start UserData Operations improved - Privacy (AntiTheft) Lock reset supported for MT6795 - Privacy (AntiTheft) Lock reset without UserData loose supported for MT6795 - UserData Safe Privacy (AntiTheft) Lock reset revised for big storage devices (16+ GiB) - PatternLock Read supported for MT6795 No need USB Debug/Root etc. Other - Latest FlashUpdate package supported (v1520) - Android 5.x OS support improved - Repair Security improved for some models - Some Bugfixes and improvements at all Official Download link Infinity-Box 10 (ten) years (2005 - 2015) non-stop regular updates and support as nobody else: Infinity-Box - News New features, Unlock Codes (Huawei, Motorola, Samsung etc.), iPhone Unlock, Software Activations released for Infinity-Box Online Service - World biggest flash files database for several thousands brands/models - BB5 Easy Service Tool [BEST] Dongle - CDMA-Tool Dongle (fast and easy unlock) - Infinity-Box Dongle ready for delivery - Follow us on Twitter |
The Following 19 Users Say Thank You to YellowBoss For This Useful Post: |
07-05-2015, 02:30 | #5 (permalink) |
No Life Poster Join Date: Jul 2012 Location: vietnam
Member: 1781157 Status: Offline Sonork: 100.1624851 Thanks Meter: 167 | how to for model http://forum.gsmhosting.com/vbb/f425...595-a-1964532/ |
07-05-2015, 02:48 | #6 (permalink) |
Member: 1781157 Status: Offline Sonork: 100.1624851 Thanks Meter: 167 | Card found: S/N xxxxxxx Chinese Miracle II [MTK module] v 1.22 Operation : Read Flash [ v1.22 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 32 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6595 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6595_S00 Processing BROM stage SecCfgVal : 0x07000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage Will use Secure DA for boot target Error : Correct DA sequence not found for target! SP SECURE Mode Enabled! Try select NORMAL SP Mode! Boot Error! Operation Failed Elapsed: 00:00:17 Reconnect Power/Cable! Operation : Read Flash [ v1.22 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:28 Reconnect Power/Cable! Operation : Read Flash [ v1.22 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 32 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6595 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6595_S00 Processing BROM stage SecCfgVal : 0x07000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage Error : Correct DA sequence not found for target! Try Re-Install CM2MTK module! Boot Error! Operation Failed Elapsed: 00:00:00 Reconnect Power/Cable! |
07-05-2015, 08:40 | #9 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, BEST Dongle users can run only Test Version (0.xx). To use release versions you need to buy Infinity-Box Dongle, for more info read here- http://forum.gsmhosting.com/vbb/f296...llers-1943689/ To activate Test Version read here- http://forum.gsmhosting.com/vbb/f641...users-1958313/ Br. |
07-05-2015, 08:48 | #10 (permalink) |
Freak Poster Join Date: Jan 2009 Location: INDIA,U.P.BALLIA
Member: 947347 Status: Offline Sonork: 100.108278 Thanks Meter: 21 | Intex Cloud Y7 Read PatternLock not ok but format ok Chinese Miracle II [MTK module] v 1.22 Operation : Check / Read Info [ v1.22 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 009800BC009000660076001500010000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0087 , UNKNOWN [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! NAND : Detecting structure now... Please, wait. NAND : Structure detect done [30] [AP] : Initial info read Ok! Done! Elapsed: 00:01:07 Reconnect Power/Cable! Operation : Read PatternLock [ v1.22 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 009800BC009000660076001500010000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0087 , UNKNOWN [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... Reading data ... Please, wait Checking ... PatternLock not set Done! Elapsed: 00:01:14 Reconnect Power/Cable! Operation : Format FileSystem [ v1.22 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 009800BC009000660076001500010000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0087 , UNKNOWN [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Format : UserData Only (Factory Reset) Format UDA block Format block Ok! Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
07-05-2015, 08:58 | #11 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Upload dump with pattern lock and post link so that it can be added. Br. | |
07-05-2015, 09:06 | #12 (permalink) | |||
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
NetworkLock , if you check update logs - exists from a long time. Quote:
07-05-2015, 09:34 | #13 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | MT6752, Safe PrivacyLock remove : Code: Operation : Reset Privacy Lock [ v1.22 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 63 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6752 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6732|MT6752_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 150100523832314D42004CD7D00B222B DA Stat : v4.2 on BBID : 0x8F DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BM128 [eMMC] : FLASH_CID : 150100523832314D42004CD7D00B222B [eMMC] : FLASH_LEN : 0x00000003A3E00000 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Checking data ... Processing with "Safe UserData" mode SafeDetect : Done! Will reset now! Privacy Lock reset Ok! Done! Elapsed: 00:00:34 Reconnect Power/Cable! |
07-05-2015, 10:45 | #14 (permalink) |
Banned Join Date: Nov 2011 Location: okara pakistan
Member: 1696883 Status: Offline Sonork: 100.1623251-JAMIL MOBILE Thanks Meter: 202 | Q Mobile X35 Write Firmware & Format Done Author Tool Format Set stuck on Q Mobile Q Mobile X35 Write Firmware & Format Done With Chinese Miracle-2 Author Tool Format Set stuck on Q Mobile logo startup MY Set Problam Unfortunately Facebook Has Stopped & Talkback- Voice Command Option Active Im Try Claer anty Theft With Miracle Box Error None Theft Code Im Format With Miracle Box Set stuck on Q Mobile logo startup im Write Firmware with Chinese Miracle-2 & Im Format With Tast Chinese Miracle-2 Aftear Flash & Format Set 100% Working Fine IM Very Hapy THANKS Chinese Miracle-2 BR JAMIL MOBILE |
The Following 8 Users Say Thank You to qasimzulfqar For This Useful Post: |
07-05-2015, 11:59 | #15 (permalink) |
Junior Member Join Date: May 2013
Member: 1938600 Status: Offline Thanks Meter: 2 | Infinity main dongle firmware update probem Hello yelloboss. I have activités m'y infinity main box since 02-07-2015. I try to update m'y dongle firmware but i can't do it. I see à message saying "jour d'ongle have thé latest firmware version. Don't try anymore". Please help me to solve this probem. |
