Old 07-04-2015, 21:44   #1 (permalink)
Member: 1043909
Thanks Meter: 46,446
Chinese Miracle-2 MTK/MediaTek v1.22 - MT6795, Android 5.x and more
MediaTek SP Platform
Flash Engine updated
- MediaTek MT6795 [HelioX10] Flashing supported
Factory FW and Dump flashing
- Factory FW writing revised for some platforms
- MT67x2 improvements
Some improvements and bugfixes
Supported CPU for Flash Writing:
MT6575, MT6577 eMMC only
MT6571, MT6572, MT6582, MT6589, MT6592, MT83xx eMMC only
MT6732, MT6752, MT6795, MT8752 eMMC only
MT8127 eMMC only
Factory FW reading improved
- MediaTek MT6795 [HelioX10] Factory FW reading supported
No need USB Debug/Root etc.
- Big firmware handling improved: MT659x, MT67xx
- Factory Firmware size now more compact - up to 2 times for some models
Service Operations improved
- "Fix Unknown BaseBand" supported for MT6795
- "DLFix" (DL Image Tool Fail error repair) supported for MT6795
- "Flash Erase" supported for MT6795
- NVRAM operations supported for MT6795
- "Format FS" (UDA + CACHE) supported for MT6795
- "Write Flash" / "Read Flash" (DUMP) supported for MT6795
- "Fix DL" during PrivacyLock reset and "Format FS" now made automatically
Unlock Operations improved
- "Direct Unlock" operation supported for MT6795
- "Read Unlock Codes" operation supported for MT6795
- New models supported
Beeline Pro 2
Beeline Smart 3
Beeline Smart 4
Beeline Tab Pro
MTS 982T
MTS Smart Start
UserData Operations improved
- Privacy (AntiTheft) Lock reset supported for MT6795
- Privacy (AntiTheft) Lock reset without UserData loose supported for MT6795
- UserData Safe Privacy (AntiTheft) Lock reset revised for big storage devices (16+ GiB)
- PatternLock Read supported for MT6795
Other
- Latest FlashUpdate package supported (v1520)
- Android 5.x OS support improved
- Repair Security improved for some models
- Some Bugfixes and improvements at all
Official Download link
Infinity-Box 10 (ten) years (2005 - 2015) non-stop regular updates and support as nobody else: Infinity-Box - News
New features, Unlock Codes (Huawei, Motorola, Samsung etc.), iPhone Unlock, Software Activations released for Infinity-Box Online Service
- World biggest flash files database for several thousands brands/models
- BB5 Easy Service Tool [BEST] Dongle
- CDMA-Tool Dongle (fast and easy unlock)
- Infinity-Box Dongle ready for delivery
- Follow us on Twitter
- Facebook
The Following 19 Users Say Thank You to YellowBoss For This Useful Post:
Old 07-04-2015, 22:00   #2 (permalink)
Member: 1043909
Test reports:
MT6795 [Helio X10] : Factory FW Read/Write!
MediaTek [Helio X10] CPU with CM2 :)
The Following 4 Users Say Thank You to YellowBoss For This Useful Post:
Old 07-04-2015, 22:58   #3 (permalink)
rehmani's Avatar
Member: 333199
Sonork: may i help u just pm me
Thanks Meter: 2,376
here is 4share link
press here to get it
The Following User Says Thank You to rehmani For This Useful Post:
Old 07-05-2015, 01:07   #4 (permalink)
ernie78™'s Avatar
Member: 1229604
Sonork: 100.1602688 CSTooL
Thanks Meter: 4,656
added remove patternlock
and support networklock smartphone MTK Chip
Old 07-05-2015, 02:30   #5 (permalink)
ngocdiemmobile's Avatar
Member: 1781157
Sonork: 100.1624851
Thanks Meter: 148
how to for model
http://forum.gsmhosting.com/vbb/f425...595-a-1964532/
Old 07-05-2015, 02:48   #6 (permalink)
Member: 1781157
Sonork: 100.1624851
Thanks Meter: 148
Card found: S/N xxxxxxx
Chinese Miracle II [MTK module] v 1.22
Operation : Read Flash [ v1.22 ]
Wait for phone...
Phone found! [ 32 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6595
BB_CPU_HW : CB00
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BB_CPU_NM : [MediaTek] MT6595_S00
Processing BROM stage
SecCfgVal : 0x07000000
BromVersion : 0x05
BLVersion : 0xFE
Preloader Status : Not active (Erased)
Processing DA stage
Will use Secure DA for boot target
Error : Correct DA sequence not found for target!
SP SECURE Mode Enabled! Try select NORMAL SP Mode!
Boot Error!
Operation Failed
Elapsed: 00:00:17
Reconnect Power/Cable!
Wait for phone...
Device boot not done
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:28
Wait for phone...
Phone found! [ 32 ]
Sync...
Boot Info :
BB_CPU_ID : 6595
BB_CPU_HW : CB00
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0x05
BLVersion : 0xFE
Processing DA stage
Try Re-Install CM2MTK module!
Boot Error!
Operation Failed
Elapsed: 00:00:00
Old 07-05-2015, 07:48   #7 (permalink)
brokendreem's Avatar
Member: 1150957
Thanks Meter: 56
mtk software not run but best dongle working fine
Old 07-05-2015, 07:52   #8 (permalink)
Member: 1707602
Old 07-05-2015, 08:40   #9 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,503
Hello,
BEST Dongle users can run only Test Version (0.xx). To use release versions you need to buy Infinity-Box Dongle, for more info read here- Infinity-Box Dongle - information for Users and Resellers
To activate Test Version read here- Chinese Miracle-2 (Test Version) free Activation for Infinity-Box [BEST] users
Br.
Old 07-05-2015, 08:48   #10 (permalink)
Member: 947347
Sonork: 100.108278
Thanks Meter: 13
Intex Cloud Y7 Read PatternLock not ok but format ok
Operation : Check / Read Info [ v1.22 ]
Wait for phone...
Phone found! [ 16 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 009800BC009000660076001500010000
eMMC_ID : 00000000000000000000000000000000
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
DA started successuflly
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0087 , UNKNOWN
[NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001
[NAND] : FLASH_LEN : 0x20000000
INT RAM : 0x00020000
EXT RAM : 0x10000000
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
NAND : Detecting structure now... Please, wait.
NAND : Structure detect done [30]
[AP] : Initial info read Ok!
Done!
Elapsed: 00:01:07
Operation : Read PatternLock [ v1.22 ]
Wait for phone...
Phone found! [ 16 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading data ...
Reading data ... Please, wait
Checking ...
PatternLock not set
Done!
Elapsed: 00:01:14
Operation : Format FileSystem [ v1.22 ]
Wait for phone...
Phone found! [ 16 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Format : UserData Only (Factory Reset)
Format UDA block
Format block Ok!
Done!
Elapsed: 00:00:12
Old 07-05-2015, 08:58   #11 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,503
Wait for phone...
Phone found! [ 16 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:01:07
Wait for phone...
Phone found! [ 16 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading data ...
Checking ...
PatternLock not set
Done!
Elapsed: 00:01:14
Wait for phone...
Phone found! [ 16 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Format UDA block
Format block Ok!
Done!
Elapsed: 00:00:12
Hello,
Upload dump with pattern lock and post link so that it can be added.
Br.
Old 07-05-2015, 09:06   #12 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 12,962
Read PatternLock - exists. It most safest way. BootPatching , like someone now move like "extrasuperblablabla" - just a half solution, which make problems for phone user.
NetworkLock , if you check update logs - exists from a long time.
Originally Posted by ngocdiemmobile View Post
As told before - NOT have MT6595 sample yet. When receive - will add.
Wait for phone...
Phone found! [ 16 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:01:07
Wait for phone...
Phone found! [ 16 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading data ...
Checking ...
PatternLock not set
Done!
Elapsed: 00:01:14
Wait for phone...
Phone found! [ 16 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Format UDA block
Format block Ok!
Done!
Elapsed: 00:00:12
In next version will be more extended NAND support. Got enough material for that.
The Following User Says Thank You to JayDi For This Useful Post:
Old 07-05-2015, 09:34   #13 (permalink)
JayDi's Avatar
Member: 462970
MT6752, Safe PrivacyLock remove :
Operation : Reset Privacy Lock [ v1.22 ]
Wait for phone...
Phone found! [ 63 ]
Sync...
Boot Info :
BB_CPU_ID : 6752
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BB_CPU_NM : [MediaTek] MT6732|MT6752_S00
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 150100523832314D42004CD7D00B222B
DA Stat : v4.2 on BBID : 0x8F
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0015 , OEM : 0100
[eMMC] : FLASH_INF : BM128
[eMMC] : FLASH_CID : 150100523832314D42004CD7D00B222B
[eMMC] : FLASH_LEN : 0x00000003A3E00000
EXT RAM    : 0x80000000
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Checking data ...
Processing with "Safe UserData" mode
SafeDetect : Done! Will reset now!
Privacy Lock reset Ok!
Done!
Elapsed: 00:00:34
Old 07-05-2015, 10:45   #14 (permalink)
Member: 1696883
Sonork: 100.1623251-JAMIL MOBILE
Thanks Meter: 202
Q Mobile X35 Write Firmware & Format Done Author Tool Format Set stuck on Q Mobile
Q Mobile X35 Write Firmware & Format Done With Chinese Miracle-2
Author Tool Format Set stuck on Q Mobile logo startup
MY Set Problam
Unfortunately Facebook Has Stopped & Talkback- Voice Command Option Active
Im Try Claer anty Theft With Miracle Box Error None Theft Code
Im Format With Miracle Box Set stuck on Q Mobile logo startup
im Write Firmware with Chinese Miracle-2
& Im Format With Tast Chinese Miracle-2
Aftear Flash & Format Set 100% Working Fine
IM Very Hapy THANKS Chinese Miracle-2
JAMIL MOBILE
The Following 8 Users Say Thank You to qasimzulfqar For This Useful Post:
Old 07-05-2015, 11:59   #15 (permalink)
Member: 1938600
Thanks Meter: 2
Infinity main dongle firmware update probem
Hello yelloboss. I have activités m'y infinity main box since 02-07-2015. I try to update m'y dongle firmware but i can't do it. I see à message saying "jour d'ongle have thé latest firmware version. Don't try anymore". Please help me to solve this probem.
Page generated in 0.56049 seconds with 7 queries
