07-06-2015, 05:37 | #32 (permalink) | ||
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Hello. You can activate TEST version for free (0.xx version of CM2 modules) or renew support and use all release versions. | ||
07-06-2015, 16:10 | #35 (permalink) | ||
I have some more interest things, let say, it will be like 100% like "user deactivate security" without any patch and reset. After this user can set anything, and there is will be no hole in boot/init scripts, which reset all security to default at startup. For now you have All MTK Android Pattern Read. Not matter eMMC or NAND. | ||
07-08-2015, 15:36 | #36 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Madagascar
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | Read Patern lock safe and sure MT6572 Code: Card found: S/N 334F:0128 Chinese Miracle II [MTK module] v 1.22 Operation : Read Flash [ v1.22 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 53 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8B00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E3958524D42003173D64A61B7 DA Stat : v4.2 on BBID : 0x88 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00A8 DRAM Init Ok , 0x10000000 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMRX9 [eMMC] : FLASH_CID : 1501004E3958524D42003173D64A61B7 [eMMC] : FLASH_LEN : 0x0000000070000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... USBDL : Init HSUSB Ok! Brand : V4 ProdName : V4 ProdModel : A68 Device : V4 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 [Read Ok] : preloader_v3_j2bom_c12_a68.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / v3_j2bom_c12_a68 / EMMC FW Size : 422 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6572__V4__A68__V4__4.2.2__ALPS.JB3.MP.V1\ All done! Done! Elapsed: 00:03:11 Reconnect Power/Cable! Operation : Read PatternLock [ v1.22 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 53 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8B00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E3958524D42003173D64A61B7 DA Stat : v4.2 on BBID : 0x88 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00A8 DRAM Init Ok , 0x10000000 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMRX9 [eMMC] : FLASH_CID : 1501004E3958524D42003173D64A61B7 [eMMC] : FLASH_LEN : 0x0000000070000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! USBDL : Init HSUSB Ok! Reading data ... FS Size : 649 MiB Magic Ok Mount point : /data Get PatternLock ... PatternLock Sequnce : 12569 Done! Elapsed: 00:00:31 Reconnect Power/Cable! |
The Following User Says Thank You to said4 For This Useful Post: |
07-08-2015, 19:24 | #37 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | New version released - http://forum.gsmhosting.com/vbb/f296...ata-l-1967261/ |
07-08-2015, 19:25 | #38 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | [BEST] Dongle and Chinese-Miracle-2: It is NOT POSSIBLE to activate latest Chinese-Miracle-2 (Release) for [BEST] Dongle for now. If you want to use latest Chinese-Miracle-2 (Release) software v1.xx you should buy and use Infinity-Box Dongle: Infinity-Box Dongle - information for Users and Resellers |
07-08-2015, 19:25 | #39 (permalink) |
07-08-2015, 19:26 | #40 (permalink) | |
What is your box S/N ? | |
07-08-2015, 19:27 | #41 (permalink) | |
11-04-2015, 22:13 | #44 (permalink) |
Freak Poster Join Date: Dec 2005 Location: Madagascar
Member: 207280 Status: Offline Thanks Meter: 15 | Hi! Who can help me for upgrade my box Infiity. This is the repport, my connexion is TELMA 8Mo ADSL: PC HWID: F340A3383EC8EBC4A1BAAC5D0A283776 Card-Reader: Axalto e-gate 0 Box/Dongle type: inf Locating server... Server address found Connecting to server Connection to server failedSocket Error # 11001 Host not found. |
