09-01-2015, 05:10 | #16 (permalink) |
Freak Poster Join Date: Jul 2009
Member: 1076060 Status: Offline Thanks Meter: 26 | hello to you infinity box service ! read it please ! but how about SPD ? spd android for example: SPD 6820/8810 ,SPD 7710 ,SPD 7710G many phone in the world is with there cpu ,need all for update please ! spd new but not android : SPD 7701B , SPD8801CE cpu in the SAMSUNG phone and other phone chinesse if infinity service will support all cpu ,it will very best again for SPD PHONE ! AND IT WILL ONLY SOLUTION ! |
The Following User Says Thank You to genylle For This Useful Post: |
09-01-2015, 06:31 | #17 (permalink) | ||||
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
09-01-2015, 10:00 | #24 (permalink) |
No Life Poster Join Date: May 2008 Location: "I work for Good weekend"
Member: 765990 Status: Offline Sonork: 100.1582347 Thanks Meter: 207 | Hi to all, In old version its ok but in new version it says DA problem Reinstal the programme once again. But tried all same error but old is gold. Phone found! [ 15 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8B00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : HYNIX [eMMC] : FLASH_CID : 90014A2058494E594816A14CCE5E2009 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : Skipped by user request FMT Mode set to : 0 Format : UserData Only (Factory Reset) Format UDA block Format block Ok! Done! Elapsed: 00:00:18 Reconnect Power/Cable! Thanks Br, Raja |
09-01-2015, 10:30 | #27 (permalink) | ||
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote: What phone model it is? Quote:
09-01-2015, 10:35 | #28 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | New version released - http://forum.gsmhosting.com/vbb/f296...ensic-1986160/ |
